Need some feedback please on a project
MoboCop
Drunken Master
Contact:
Post by MoboCop »
Toby B. wrote::mb_bangdesk::
Code: Select all
$rlink = 'http://www.intel.com/design/motherbd/oem/index.html'
I really need to learn to pace myself... :roll:
Code: Select all
<?php
if ($retail == None) {
   echo "There is no retail information availible.";
} else if ($rlink != None) {
   echo "<a href='".htmlentities($rlink)."'>$rlink</a>";
if ($rlink2 != None)
   echo "<a href='".htmlentities($rlink2)."'>$rlink2_descript</a>";
Havent tried to use 2 links at a time with the updated code, but I got the single links figured out... :oops:
Have a question. What is None? Why do you use it?
Toby B.
Contact:
Post by Toby B. »
Too newb to PHP to figure out the correct way... :P
Toby B.
Contact:
Post by Toby B. »
Well I made a bit of progress. I am replacing "None" with False or True in the else if statements. Working pretty good so far.
The one issue that I am noticing with the code it the in the parsed links (i.e. the URLs that show on the HTML pages), the double quotes wont show like
Code: Select all
<a href="test_page.html">Test link decription</a>
It eith shows up as:
Code: Select all
<a href=test_page.html>Test link decription</a>
or:
Code: Select all
<a href='test_page.html'>Test link decription</a>
Either way the links are funtional. Just looks strange when viewing the source... :?
MoboCop
Drunken Master
Contact:
Post by MoboCop »
Toby B. wrote:Well I made a bit of progress. I am replacing "None" with False or True in the else if statements. Working pretty good so far.
Code: Select all
Code: Select all
or:
Code: Select all
If these are parsed then you need to do this
Code: Select all
'<a href="test_page.html">Test link decription</a>'
Toby B.
Contact:
Post by Toby B. »
well hereis what I was able to accomplish:
Code: Select all
$b_docs = '"http://www.fica.com/site/html/services/faq_detail.asp?c_id=240000477"';
$bdocs_descript = "Jumper Settings";
Code: Select all
<?php
if ($b_docs == false) {
   echo "None";
} else if ($b_docs == true) {
   echo '<a href='."$b_docs".'>'.$bdocs_descript.'</a>';
Setting up the HREF's like this works perfectly.. 8)
MoboCop
Drunken Master
Contact:
Post by MoboCop »
Toby B. wrote:well hereis what I was able to accomplish:
Code: Select all
Code: Select all
<?php
   echo "None";
Great.
Toby B.
Contact:
Post by Toby B. »
Thanks for the help/advice Patrick... :wink:
I know I am a little ahead of myself in the whole coding area.. But I am learning more and more each day.. Even if I have look like a complete dumbass and/or go round and round cause I am too vague on what I am trying to do...
MoboCop
Drunken Master
Contact:
Post by MoboCop »
Toby B. wrote:Thanks for the help/advice Patrick... :wink:
Just keep plugging away. No one thinks you are a dumbass.
~Rob
Contact:
Post by ~Rob »
I know you are using php, but I'm a java guy so can you use line thingies like
Code: Select all
public void example() //This line declares something
[img]http://i3.photobucket.com/albums/y83/RobPope/sigmove.gif[/img]
[b]Jocuri cu impuscaturi[/b] si alte genuri, pentru toate varstele doar pe [url=http://smarturl.it/jocuri]acest link[/url] - distractie si amuzament garantat!
Post Reply
