returning arrays c++
Postby bdiec482 » Thu May 12, 2005 4:00 am
Hey all,
Believe it or not, i teach computer science at a high school in northern wisconsin. Which means i have had two semesters of c++ in college. I can't remember how to return an array from a function. One of my students is on me to figure this out. This class i am teaching is not learning about pointers, but i suspect pointers is the way to go. Could someone write a two line function with the syntax on how to return an array? Thanks so much, and don't worry...i won't give myself credit for the discovery. haha
Code hard,
Postby Roach412 » Thu May 12, 2005 5:44 am
Returning an array from a function: (how to return an array from a function)
Something really annoying about C++ is that you can't return an array from a function (method) like one does in Perl or Java. You have to create the array before calling the function, then call the function, passing a pointer to the array. Within the function, the array is filled.
Code: Select all
void CRomeView::test (int* x)
 x[0] = 21;
 x[1] = 10;
void CRomeView::test2 (CString* x)
 x[0] = "text1";
 x[1] = "text2";
Calling the function:
int myint[2];
AfxMessageBox( myint[1] );
CString cs[2];
AfxMessageBox( cs[1] );
After calling the function, we have the 'return' values in the array we created before.
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
Logitech G402 Hyperion Fury
Postby pa3lsvt » Thu May 12, 2005 6:20 pm
That being said, if you truly want to "return" an array from a function, you have to use pointers as you mentioned. Technically, it's just passing addresses as pointers and then treating them as if they were an array, which is really just a pointer and an offset = index * sizeof(var-type).
Something along these lines, except I seem to think that this should involve '&' (addressof operator) somewhere for some reason:
Code: Select all
int* mysub(int init)
     int myarray[3];
     for (int i = 0; i < 3; i++)
          myarray[i] = init++;
     return myarray; //might be: return myarray&;
int main()
     int* values = mysub(int(10));
          cout << "myarray[" << i << "] = " << values[i] << endl;
myarray[0] = 10
myarray[1] = 11
myarray[2] = 12
Returning Pointers
Postby BorderGuard » Sat Jul 16, 2005 8:25 pm
Being at about the same level as you, with 3 courses in C++ I can see both of the aforementioned methods but you have to be a little farther along to see Roach 412s method. Pointers and address of operators have given me problems in the past and I have been taught both ways. Both ways look good to me but I did not even see the 412s method until my 2nd semester so therefore I would favor pa3lsvts.
I hope I am not too confusing but from someone who has had the same problems in the past that is my recommendation.
Postby SkReaP » Mon Jul 18, 2005 8:51 am
I might be oversimplifying, but you can just do this (if I understand the question)
void main(void)
int Array[10];
void func1(int &Array)
Or something like that. Haven't used C++ in a while. (kinda sad - I have a degree in computer science!)
Return to Programming
