It is currently Tue Apr 07, 2020 6:20 pm
PostPosted: Wed May 04, 2005 6:11 am
Trying to use a table as a dropdown's datasource but this error drives me crazy. Somebody help please.
PostPosted: Tue Jul 26, 2005 5:58 pm
Best bet is:
http://groups-beta.google.com/grphp?hl=en&tab=wg&q=
PostPosted: Sun Jul 31, 2005 3:12 am
Sounds like the password and/or username you're using to connect to the database is wrong. Or you need to tweak with the account settings of your database system
PostPosted: Wed Dec 07, 2005 2:48 pm
Location: Hopefully near that chick above this, love that mask
Create a UDL file based on you MSSLQ connection then you will know if your connection string works
"God didn't create Rambo. I created him... "
me @ www.....
PostPosted: Wed Dec 07, 2005 8:00 pm
the specific user that you're attempting to access with...do they have persmissions on the hardware that's running the server? what are you running this on? VB? ASP? C#? what versions? this all can be very helpful. :D
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Thu Dec 08, 2005 10:37 am
Looks like java to me. Use a try catch for the sql exception. if its .NET it will be similar.
Code:
try
  //Your database stuff here
catch (SQLException e)
   // handle error processing
It looks like your username and password are not being found in the database so you need to write some elegant error handling for such an occurence.
