Does this look right...
Postby ~Rob » Wed Apr 13, 2005 11:57 am
Trying to make an autorun CD for my ICT project. It's just to be a teachers pet really.
I have the user documentation in the form of a website with the main page index.html and want it to autorun
Is it:
Code: Select all
[Autorun]
open=index.html
or do I need more? Also, what size are icon images?
~Rob
Postby Toby B. » Thu Apr 14, 2005 1:45 am
No clue as to if that's sufficient or not. Might be worthwhile to give it a try and see what happens. As far as the icon pics - should be something easily figured out if your the one creating this...
If you are asking how to size the images, you can just use HTML code to do that..
Toby B.
Postby ~Rob » Thu Apr 14, 2005 7:21 am
All done now, I used a freeware program that does it. Nearly hit something trying to figure it out and went through 6 CD's!
~Rob
Postby Toby B. » Thu Apr 14, 2005 7:30 am
cool
Toby B.
Postby netaces2k » Fri Apr 22, 2005 12:42 am
As an example, find your Windows CD-ROm or any retail software CD and take a look at the autorun.ini.
netaces2k
Postby evasive » Sat Apr 23, 2005 5:01 am
autorun.inf
usually
[autorun]
open=start index.htm
However, if you do this, Windows displays a DOS box briefly, which looks nasty. (And start might not be available on some systems.)
If you are only targeting recent Windows systems, then you can use the shellexecute command to open a file without a flickering DOS box:
[autorun]
shellexecute=index.htm
if you want something else, there are little tools around that open the file for you.
Return to Programming
