It is currently Sun Aug 19, 2018 5:47 pm
 Post subject: Motherboard gname
PostPosted: Wed Apr 06, 2005 3:24 am
Hi Folks
How does one find the model name of a motherboard? Prefereably through software.
TIA
Andrew Sprott
http://astronomy.crysania.co.uk
PostPosted: Wed Apr 06, 2005 3:17 pm
Try reading the stickies at the top of the 'Motherboard Identification' section.
PostPosted: Thu Apr 07, 2005 7:49 am
Err, sorry, maybe I didn't make myself clear. This is the programming section right :]
How can a program running under windows find the model name of the motherboard?
It can be done because Sisoft Sandra does it.
Andrew Sprott
PostPosted: Sun Apr 10, 2005 3:52 am
well I was looking for the same sort of thing and came across this:
using visual basic 6
http://vbnet.mvps.org/index.html?code/w ... eboard.htm
or simply search for "Obtaining Baseboard information using WMI" in yahoo and you chould get the same page as the first result of the search.
-dve83- Folding for 33258
Gigabyte GA-MA69VM-S2,AMD Athlon X2 5200+, 6GB DDR2-800, Seagate 250GB 7200 RPM, Western Digital 1TB 7200RPM,
460W Coolermaster PSU, Windows 7
"Perhaps it's not paranoia. Perhaps it's just finesse." - dve83
PostPosted: Tue Apr 12, 2005 7:58 am
Well, I was hoping for something that works with Delphi.
TIA
Andrew Sprott
PostPosted: Sat Apr 23, 2005 1:16 am
I know that I'm going to take alot of crap for this...
But. Delphi is a scripting language based entity. It is not suitable for technical programming. It's a waste of time to do it.
If you want to do it in VB6, fine. But Delphi? Nope.
You will need to use function calls (user defined) to access the BIOS from the OS. And there are issues with the 2000 / XP OS's. Because of the permissions. Only Admins can access the hardware directly. Which is so dumb....
PostPosted: Sat Apr 23, 2005 4:58 am
Ever administered a network? I guess not, else you wouldn't say this :twisted:
PostPosted: Sat Apr 23, 2005 7:39 am
Hi
I don't think you really know what you are talking about. Delphi is *not* an interpreted language, when VB *is*
Anyway accessing the information I want is pretty easy and does not require any interaction with windows or the BIOS.
Andrew
Andrew Sprott
PostPosted: Tue Apr 26, 2005 8:47 am
Hi Ppl
As a matter of inerest, when I access memory will $F000000 always point to the BIOS.
TIA
Andrew Sprott
PostPosted: Tue Apr 26, 2005 8:54 am
Sorry, slight error there, I meant $F0000
Andrew
Andrew Sprott
