Forms and PHP
Forms and PHP
Postby Falklian » Thu Mar 17, 2005 4:20 pm
On my website I have a news submission form, with a dropdown box for a person to enter his/her name. Since I'm the only one who ever posts any news, I figured everything was working correctly. Well, today I added a new user and found out it is broken :oops:
This is what I have:
Code: Select all
<select name="name">
  <option value="" selected>---Select---</option>
  <option value="Athaniel">Athaniel</option>
  <option value="Borador">Borador</option>
  <option value="Fayrwel">Fayrwel</option>
  <option value="Unsane">Unsane</option>
  <option value="Verdin">Verdin</option>
</select>
Now, originally I figured the value would end up in the name variable. Silly me, it doesn't seem to work that way. It seems the very last name in the list is always stored in the name variable. I've selected the other names and the last name ends up in the variable, I've even not selected a name and I get the same results.
Here's my PHP code:
Code: Select all
<?php
  $date = date("l dS of F Y h:i:s A");
  if(empty($title) || empty($text) || empty($name))
    echo "You didn't completely fill in the form!  Please click the back button on your browser and make sure you filled out the name, article title, and news item sections.";
  else
    echo "Thank you for submitting a news item!  Please return to the index page to see your post!";
    mysql_query("INSERT INTO news (name,date,title,text) VALUES ('$name','$date','$title','$text')");
The form method is POST by the way.
Edit: Nevermind! I fixed it! I changed <select name="name"> to <select name="toon"> and it works now! Seems you shouldn't assign the value "name" to a variable called "name" :wink:
Falklian
Return to Programming
