It is currently Wed Sep 19, 2018 9:05 pm
 Post subject: spacing in java
PostPosted: Sun Feb 13, 2005 1:52 pm
I have a completed java program that takes an expression and solves it. The program works fine expept i need to print the final answer like this:2+2=4 and it doesnt. It puts the answer on a different line. Does anyone know what i did wrong?
Here is the program:
Code:
import java.util.*;
import java.io.*;
public class Calc1
  //prompts the user for input and calls necessary methods
  public static void main(String args[])
    String cont = "";
    do
      System.out.println("Please enter a numeric expression.");
      StringTokenizer exp = new StringTokenizer(Calc1.getInput(), "+-*/%", true);
       System.out.println(Calc1.getInput() + "=" + Calc1.performOperation(exp));
      System.out.print("Do you want to enter another expression? (y/n): ");
      cont = Calc1.getInput();
    }while(cont.equalsIgnoreCase("y"));
     System.out.println("Goodbye");
   //gets a single input from the user, and returns it as a String
  static String getInput()
    java.io.InputStreamReader input = new java.io.InputStreamReader(System.in);
    java.io.BufferedReader console = new java.io.BufferedReader(input);
    try
      return console.readLine();
    catch(java.io.IOException e)
      System.err.println("Bad NEWS!!!");
      return "";
  //performs requested operation
  static int performOperation (StringTokenizer exp)
    int num1 = 0;
    int result = 0;
    String check = "";
    String sve = "+";
    do
      check = exp.nextToken();
      if(!check.equals("+") && !check.equals("-") && !check.equals("*") && !check.equals("/") && !check.equals("%"))
        num1 = Integer.parseInt(check);
        if(sve.equals("+"))
          result = result + num1;
          num1 = 0;
        else if(sve.equals("-"))
          result = result - num1;
        else if(sve.equals("*"))
          result = result * num1;
        else if(sve.equals("/"))
          result = result / num1;
       else if(sve.equals("%"))
         result = result % num1;
      else
        sve = check;
    }while(exp.hasMoreTokens());
    return result;
