Re-read MSI
Re-read MSI
Postby poundu1 » Thu Jan 20, 2005 3:35 am
Negative. If you look at the text with such a mind set as to see it that way.
The facts are, as listed in the previous post, and mind you I am not seeking that you analize this as an optimust, as these ARE the facts. Receipt and cancelled checks for the product as well as the well worn CD, its case and the indicia included in the package. ................T B
I must say Toby that your administration of the topic may have from one perpective been waranted. However if your mom had posted that, you surely wouldnt have questioned her integrity.
Best Regards
Mark
dharb
crispr edit
poundu1
Postby Toby B. » Thu Jan 20, 2005 7:43 am
The game works.
I tried to apply a mod for the game, and the mod gos all the way to the end of its setup file and says "Ghost Recon must be installed prior to running this setup".
The game is NOT in the add and remove programs list.
As I said before this is not supported here!!!
Toby B.
Return to Programming
