shapes in java
shapes in java
Postby cwl157 » Thu Jan 06, 2005 5:01 pm
i kinda know how to draw shapes in java but i have a couple questions.
Here is the code i used:
Code: Select all
/* Import the code to draw pictures & shapes */
import java.awt.*;
/* Import the code to display as an applet */
import java.applet.Applet;
public class House extends Applet {
    public void paint (Graphics page) {
        setBackground(Color.lightGray);  //sets the applet background to lightGray
        //setForeground(Color.white);
        page.setColor(Color.red);  //set the foreground color the color object we created
         // param 1 is x distance (the "X" coordinate)
         // param 2 is y distance down (the "Y" coordinate)
         // width is the width of the rectangle
         // height is the height of the rectangle
        page.fill3DRect(50, 300, 150,150,true);  //draw an opaque rectangle
        page.setColor(Color.yellow); // set the color yellow
        page.fillOval(50, 150, 75, 75);    //this draws an opaque oval
I have 2 questions. My first is how do i run this as a program and not an applet and how do i draw triangles and lines in java? Thanks
cwl157
Postby olly » Thu Jan 06, 2005 11:40 pm
olly
Re: shapes in java
Postby olly » Fri Jan 07, 2005 2:36 am
cwl157 wrote:My first is how do i run this as a program and not an applet
You can use a frame. Here is an example of a Frame:
Code: Select all
import java.awt.*;
import java.awt.event.*;
public class FrHouse extends Frame
   //If you embed the main method in your frame class
   //You dont need a seperate application class
   public static void main(String[] args)
      FrHouse myFrame = new FrHouse(); //Create a frame object
      myFrame.setVisible(true); //Make it visible
   //Constructor
    public FrHouse()
        setTitle("My Frame"); //Frame title
        setSize(500, 500); //Frame size
        setLocation(100, 100); //Frame location
        setBackground(Color.lightGray); //Frame background colour
        addWindowListener(new WlsFrame());
    //Terminating an application when user closes the frame
    class WlsFrame extends WindowAdapter
      public void windowClosing(WindowEvent we)
         System.exit(0); //Terminates the application
olly
Re: shapes in java
Postby olly » Fri Jan 07, 2005 2:43 am
cwl157 wrote:how do i draw triangles and lines in java? Thanks
I think you can make use of the classes:
Graphics &
Graphics2D
In the java.awt package.
Check the docs:
Java 2 Platform API Specification -> java.awt -> Graphics & Graphics2D
olly
Return to Programming
