It is currently Thu Aug 16, 2018 2:02 pm
PostPosted: Tue Dec 21, 2004 6:11 am
I am writing a program to compress data and it would be nice if there was a function to perform file I/O operations not by bytes but by bits. Is there any function?
Thanks.
PostPosted: Wed Dec 29, 2004 4:07 am
Pkzip does the data compression bit by bit to consolidate the 0s. With machine language programs, compression is only 10%. All programs use native machine language, so bit by bit compression is a thing of the past. You have to study more modern data compression mothods to keep up to date. HDD use PRML, and graphics has 900% compression.
Bit by bit you have to take them from the dram in bit streams.
