CRON-jobs
CRON-jobs
Postby Toby B. » Wed Nov 03, 2004 11:08 pm
What are CRON-jobs? Are they very useful for growing sites? Where do I find out if my site/server accepts the use of CRON-jobs?
My site is aimed at Compaq/HP motherboard/system info and with some sheer confusion showing its ugly face more and more I have opted to integrate links on the individual pages to a forum section (much like your Articles/reviews). I would like to automate this if possible, but do not know where to start.... As it stands right now I have 73 board (HTML) pages linked to my forum and this has not even scratched the surface....
Any ideas?
Thanks
Toby B.
Postby Toby B. » Thu Nov 04, 2004 3:44 am
Well it seems the hosting package I have does allow cron-jobs. Now I just have to figure out more about them....
Toby B.
Postby MoboCop » Thu Nov 04, 2004 4:02 am
cronjobs allow you to run a program or a script at specific times.
I use cronjobs currently to grab the folding stats from standford every three hours and update the database.
Cronjobs are used also by the webservers to rotate logs and other housekeeping functions.
If you have something you think you want to setup on cron I can explain what needs to be done to get your program or scripts setup in the crontab.
MoboCop
Drunken Master
Postby Toby B. » Thu Nov 04, 2004 4:11 am
Are you using a cron-job with the articles/reviews to add a post to the forum or is that something entirely different???
I am looking to automate (if possible) this process - New/updated page(s) when uploaded has a corresponding post/tread created in my forum... Like I said, I am at 73 posts right now and have not even scratched the surface...
Did I confuse you yet? 8O
Toby B.
Postby MoboCop » Thu Nov 04, 2004 10:29 am
no I dont use it to update forums.
To accomplish this first you will need a script that when run will update your forums properly.
Once this script is working it is easy to setup a cron job to run the script at certain intervals.
On the other hand if you upload the pages manually you could always run the script from a browser after you upload.
MoboCop
Drunken Master
Postby Toby B. » Thu Nov 04, 2004 2:27 pm
Any tips, etc. for setting up such a script? And as far as manually running the script, that would be no problem really.
At least I was able to explain it well enough so you know what I was wanting to do... :wink:
Thanks
Toby B.
Postby MoboCop » Thu Nov 04, 2004 8:08 pm
if you are using phpbb the easiest way is to use the custom function insert post which is a third party function you can find searching the phpbb forums.
It comes with some basic instructions which should help you get started (if you know php you should be ok).
MoboCop
Drunken Master
Postby Toby B. » Thu Nov 04, 2004 9:11 pm
ok great.. Thanks!
I am still a php newbie, but I can usually get it figured out with some trial and error... :wink:
Toby B.
Postby Toby B. » Fri Nov 05, 2004 11:16 pm
MoboCop wrote:if you are using phpbb the easiest way is to use the custom function insert post which is a third party function you can find searching the phpbb forums.
I found a MOD "InsertPost", but cannot figure it out for the life of me... :oops:
Toby B.
Postby MoboCop » Sat Nov 06, 2004 1:28 pm
Once you have it installed you need to write a script that calls the function
insert_post()
You will need to fill the variables with your data.
You also might want to read through the post on phpbb about it it is huge and lots of questions asked in there.
Also there is a link to the guys website and he has some forums there as well.
MoboCop
Drunken Master
Return to Programming
