Using GIF animations in VB6.0
Postby asameer87 » Thu Sep 30, 2004 11:54 am
Hey u VB gurus out there... Just tell me how to use animating GIF images in VB??? The picture control or the image control doesn't work. I tried many other ACTIVE X controls but couldn't find a siutable one.. Please tell me how to do it..
Dont u ask me to put a timer and change the images!!!! :lol:
asameer87
Postby asameer87 » Sun Oct 03, 2004 12:09 pm
    MAN... DOES NOBODY KNOW ANYTHING ABOUT MICROSOFT VISUAL BASIC 6.0??????
    THAT'S A SURPRISE... I DONT THINK ITS TOO MUCH OF A DIFFICULT QUESTION??? HUH
asameer87
Postby SnyperX » Sun Oct 03, 2004 12:13 pm
well then you should be able to find the answer yourself. insulting the people here will not help any bit at all
P4 3.2 Prescott LGA-775
X600Pro PCI-E (not the best but cheap and decent)
Gigabyte GA-8I915P Duo-A
Geil UltraX 2-2-2-5 1gig Dual Channel
PSU
http://www.xpcgear.com/jaguar450psu.html
28a on the +12v
SnyperX
Postby thomas_w_bowman » Tue Oct 05, 2004 5:32 am
I used timing and sprites in BASICA (DOS 2.1), but Microsoft keeps 'upgrading' VB and I won't convert and re-learn fast enough to keep up - For animation, I would try C++ (or some tight assembler routines using direct GPU interfaces), for workstation or Web I would prefer JAVA, which will be more stable and 'backward compatible' as future versions arise.
Shouldn't you be using 'Visual Studio' (or whatever Micro$oft's latest is) now ?
Join Folding team #: 33258
thomas_w_bowman
Postby asameer87 » Tue Oct 05, 2004 12:29 pm
Man!! I am just a beginner to this language and was just tryin to find some help!!! I am not insulting, rather I am challenging the masters of this language(if any) to come up with a solution... DO YOU HAVE IT????
asameer87
Postby thomas_w_bowman » Tue Oct 05, 2004 1:12 pm
We're motherboards.org, not programming.org...
Seems a bit more confrontative than needed. You win. There may not be any here. :lol: When you find the answer, please post it so that we might learn. :wink:
thomas_w_bowman
Postby thomas_w_bowman » Tue Oct 05, 2004 1:13 pm
Another thought...
Why not ask Micro$oft ???
thomas_w_bowman
Postby asameer87 » Thu Oct 07, 2004 1:46 am
Then why have a PROGRAMMING FORUM???????????????
I guess I annoyed you people... But as I said!! I amonly trying to find an ANSWER.
asameer87
Postby thomas_w_bowman » Thu Oct 07, 2004 6:32 am
Because I want you to be able to succeed at learning to program, and perhaps to interact with others without being exceediingly annoying - there are two things I would suggest you keep in mind - especially when requesting free help...
1) ALL CAPS IS A LOT LIKE SHOUTING, AND WORSE WHEN BOLD
2) Excessive Use of exclamations or question marks can imply a severe lack of patience and tolerance - thus might be annoying. Two would indicate a sufficient extreme !!
These are largely why you come across as a screaming, impatient, ungrateful fool. Mellow out a little, the Programming forum is fairly new here - if you like it, respect it.
Well, one thing that happens a lot on these forums, is that we refer folks to where they need to look for help - try this - and let us know what you found.
http://msdn.microsoft.com/vbasic/support/default.aspx
thomas_w_bowman
Return to Programming
