It is currently Fri Oct 19, 2018 7:30 am
 Post subject: stupid java question
PostPosted: Wed Sep 22, 2004 9:00 am
Hey guys I am doing an assignment for Java and I need to find the last digit in a value entered by the user.
for example:
If the user entered: 12344321566
i need to find the last 6
then divide the full # by 7 to see if the remainder is = to 6
even the smallest help is appreciated. thanks
PostPosted: Wed Sep 22, 2004 9:46 am
The last digit of a number is its remainder (modulus) when divided by 10.
In Java, like in C and C++, the % operator is used for remainder.
So, if your number is stored in a variable of type int called num, this will give you the last digit:
num%10
And this will give you the remainder when divided by 7:
num%7
So, your condition would be:
if (num%7==6) ......
So, an assignment...I'll try to help without doing it for you...by breaking down some implicit functional requirements:
User-entered value has a length, set a variable to that length-1
set a one-character to the value at (length-1)
Check that single-character variable for valid numeric value (yes, you may have defined input as numeric, but this way it'll never crash because of any change(s).)
Convert the character to a numeric value, divide it by seven (or "if less than 7 - it's already a remainder - else if it's 7 or more subtract 7 and the result is a remainder). For larger intigers, divide by seven - forcing answer to a integer-only value, then multiply that value by 7 and subtract it from the original number to obtain the remainder (making sure that you use integer type numerics for all of this, it would get messy if using a floating point number or any decimal places).
Now turn the requirement into Java.
Join Folding team #: 33258
