It is currently Thu May 28, 2020 2:12 pm
 Post subject: javascript help
PostPosted: Mon Aug 16, 2004 9:52 pm
Code:
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html>
<head>
<TITLE>Untitled</TITLE>
<link rel="STYLESHEET" type="text/css" href="./../../common/cstechstyle.css">
</head>
<body bgcolor="#999999" text="white" link="white" vlink="white" alink="white">
<SCRIPT language="javascript1.1">
   infoOn = new Image()
   infoOn.src = "./../../images/getinfodown.gif"
   infoOff = new Image()
   infoOff.src = "./../../images/getinfoup.gif"
function changeImg(cImg,ref) {
document.images[cImg].src = ref.src
</SCRIPT><table width="100%" border="0">
<tr>
<td align="left" valign="top" class="submenuheading"><a href="sidenav.html"><font color="yellow">Back</font></a></td></tr>
       <tr><td height="50"></td></tr>
   <tr><td align="center" valign="top" class="submenuheading">Quickspecs</td></tr>
         <tr>
<td align="center" valign="top">
<a href="5bw1xx/5bw112/5BW112quickspecs.html" target="content"
onMouseOver="changeImg('info',infoOn)"
onMouseOut="changeImg('info',infoOff)">
<img name=info src="./../../images/getinfoup.gif" border=0></a></td> </tr><BR>
   <tr><td align="center" valign="top" class="submenuheading">Heading 2</td></tr>
         <tr>
</table>
</html>
I needing to get the above code working properly or have it redone to work properly. I cannot get it figured out at all. The above code works properly if I remove the entire "Heading 2" block from the code.
thanks for any help...
Compaq-Fu Master
PostPosted: Thu Aug 19, 2004 9:51 am
I'm not as deep into javascript as you appear to be, but I have a couple of questions.
What exactly are you trying to accomplish? Do you want the image to change when the OnMouseOver event occurs and that isn't working?
I can't replicate your page and troubleshoot as I don't have access to the style sheet or the images.
Shouldn't the <script> tags be in the <head> section?
Once I have a better idea of what is supposed to happen and what isn't happening, I may be able to help troubleshoot a bit. Do you have a URL I could go to and check out the page itself?
tryn
PostPosted: Thu Aug 19, 2004 12:59 pm
Will have a url availible later on this evening......I have moved the <script> block into the <head> tags as suggested and made no difference.
What I am trying to accomplish is a universal code that I can adjust when needed to work with one or two rollover "instances". What I end up with now (when trying to have 2 rollover "instances"), is I roll the mouse over link/image 1 and link/image 2 lights up. When its just one link/image everything works flawlessly.. :roll:
Compaq-Fu Master
PostPosted: Thu Aug 19, 2004 2:17 pm
http://www.s87841630.onlinehome.us/quic ... bw112.html
Compaq-Fu Master
PostPosted: Thu Aug 19, 2004 2:44 pm
I don't have time atm to error check your code, but this is the rollover script I use, if you want it. It's originally from dreamweaver, but found it to work well, so I use it even when hard coding.
This goes in the <head>
Code:
<script language="JavaScript">
function MM_swapImgRestore() { //v3.0
  var i,x,a=document.MM_sr; for(i=0;a&&i<a.length&&(x=a[i])&&x.oSrc;i++) x.src=x.oSrc;
function MM_preloadImages() { //v3.0
  var d=document; if(d.images){ if(!d.MM_p) d.MM_p=new Array();
    var i,j=d.MM_p.length,a=MM_preloadImages.arguments; for(i=0; i<a.length; i++)
    if (a[i].indexOf("#")!=0){ d.MM_p[j]=new Image; d.MM_p[j++].src=a[i];}}
function MM_findObj(n, d) { //v4.0
  var p,i,x;  if(!d) d=document; if((p=n.indexOf("?"))>0&&parent.frames.length) {
    d=parent.frames[n.substring(p+1)].document; n=n.substring(0,p);}
  if(!(x=d[n])&&d.all) x=d.all[n]; for (i=0;!x&&i<d.forms.length;i++) x=d.forms[i][n];
  for(i=0;!x&&d.layers&&i<d.layers.length;i++) x=MM_findObj(n,d.layers[i].document);
  if(!x && document.getElementById) x=document.getElementById(n); return x;
function MM_swapImage() { //v3.0
  var i,j=0,x,a=MM_swapImage.arguments; document.MM_sr=new Array; for(i=0;i<(a.length-2);i+=3)
   if ((x=MM_findObj(a[i]))!=null){document.MM_sr[j++]=x; if(!x.oSrc) x.oSrc=x.src; x.src=a[i+2];}
</script>
Use the <body> tag to preload your rollover images:
Code:
<body bgcolor="#FFFFFF" text="#000000" onLoad="MM_preloadImages('images/image_up.jpg')">
Then your img tag looks like this:
Code:
<a href="link.html" onMouseOut="MM_swapImgRestore()" onMouseOver="MM_swapImage('Rollover1','','images/image_up.jpg',1)"><img name="Rollover1" border="0" src="images/image_down.jpg"></a>
"I disapprove of what you say, but I will defend to the death your right to say it"
-Voltaire
 Post subject: Re: javascript help
PostPosted: Thu Aug 19, 2004 2:53 pm
I think I just figured your problem: Both your images are named 'info'. Change the code for the second image to this, it should work:
Code:
onMouseOver="changeImg('info2',infoOn)"
onMouseOut="changeImg('info2',infoOff)">
<img name=info2 src="./../../images/getinfoup.gif" border=0></a>
-Voltaire
PostPosted: Thu Aug 19, 2004 3:00 pm
ok thanks a bunch...
you don't happen to post over at webmaster-talk.com do you?
Code:
<html>
<head>
<BASE HREF="http://www.s87841630.onlinehome.us/">
<link rel="STYLESHEET" type="text/css" href="common/cstechstyle.css">
x.src=a[i+2];}
</script>
</head>
onLoad="MM_preloadImages('/images/getinfodown.gif')">
infoOn.src = "images/getinfodown.gif"
infoOff.src = "images/getinfoup.gif"
</SCRIPT>
<tr>
</tr>
<tr>
</tr>
<tr>
</tr>
<tr>
<td align="center" valign="top"> <a href="PC Theater/9100/9100quickspecs.html"
target="content"
onMouseOut="changeImg('info',infoOff)"> </a><a
href="PC%20Theater/9100/sytemboard.html" onMouseOut="MM_swapImgRestore()"
onMouseOver="MM_swapImage('Image2','','/images/getinfodown.gif',1)"><img
name="Image2" border="0" src="/images/getinfoup.gif" width="103"
height="12"></a></td>
</tr>
<BR>
<BR>
<tr>
<td align="center" valign="top" class="submenuheading">Jumpers</td>
</tr>
<tr>
<td align="center" valign="top"> <a href="PC Theater/9100/sytemboard.html"
target="content"
onMouseOut="changeImg('info',infoOff)"> <img name=info src="images/getinfoup.gif"
border=0></a></td>
</tr>
<BR>
</table>
</html>
That is what I got from a member there. Seems to work perfectly when the links are properly setup........... :oops:
When seting this above code up I failed to notice the BASE href. Thus throwing everything else off... :roll:
Between the two codes I should be good to go now... 8)
Compaq-Fu Master
PostPosted: Thu Aug 19, 2004 3:38 pm
Nah, that wasn't me :D
I guess that script is pretty popular thanks to dreamweaver. It works well across browsers, and preloads the images, which is what I like.
Hope it works out for ya.
-Voltaire
PostPosted: Thu Aug 19, 2004 5:34 pm
Well except for rewriting a bunch of code things are starting to lookup for this project.... :D
thanks again for the help..
Compaq-Fu Master
