It is currently Tue Dec 11, 2018 6:44 am
 Post subject: VBScript question
PostPosted: Tue Jan 27, 2009 1:28 am
Hi, I'm a bit stupid and I'm not altogether brilliant at VBS anyway. My problem is a "name redefined" error. I think I understand what's happening, but my problem is with these lines:
Code:
const NumSourceFiles = 3
dim SourceFiles()
redim SourceFiles(NumSourceFiles)
SourceFiles(0) = "C:\test_source1\*.*"
SourceFiles(1) = "C:\test_source2\*.*"
SourceFiles(2) = "C:\test_source3\*.*"
This is part of a much bigger script. I'm trying to make a backup system. The problem seems to be that when the line dim SourceFiles(), it's then redefined in redim SourceFiles(NumSourceFiles) and VBS goes all funny. Any ideas?
PostPosted: Tue Jan 27, 2009 1:33 am
http://bizincusa.com/casp/html/vbscript ... tement.htm
PostPosted: Tue Jan 27, 2009 1:36 am
As far as I can tell, that's exactly what I'm doing. So why does the script not like it?
PostPosted: Tue Jan 27, 2009 2:36 am
check if you're not using
dim SourceFiles
without the () elsewhere. If you are, you're dimming twice which is illegal.
