It is currently Sat Dec 15, 2018 8:02 pm
PostPosted: Mon Jan 21, 2008 12:54 pm
i have an HTML file that auto loads when a user starts the computer, the file explains certain things about the system to new owners who buy it. after they read it, they can delete it at will.
something new in the file or maybe something different about xpsp2c has caused the file to come up with an activex warning everytime the file opens in explorer. is there any way i can get explorer to ignore this warning for just this one file without changing security settings for the whole computer?
thanks.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
PostPosted: Mon Jan 21, 2008 10:24 pm
Get the ActiveX element signed by Microsoft perhaps? What element are you using anyway?
PostPosted: Tue Jan 22, 2008 6:54 am
thanks for the reply...
I'm not sure what activeX content is in the file. it worked fine on machines with xpsp2b, and only one thing was added to it since then...
the area close to and above this code...
<a
href="http://www.avid.com/support/downloadcenter/accountRequest.asp">http://www.avid.com/support/downloadcenter/accountRequest.asp</a>
here is the file in full...
<html xmlns:v="urn:schemas-microsoft-com:vml"
xmlns:o="urn:schemas-microsoft-com:office:office"
xmlns:w="urn:schemas-microsoft-com:office:word"
xmlns:st1="urn:schemas-microsoft-com:office:smarttags"
xmlns="http://www.w3.org/TR/REC-html40">
<head>
<meta http-equiv=Content-Type content="text/html; charset=windows-1252">
<meta name=ProgId content=Word.Document>
<meta name=Generator content="Microsoft Word 11">
<meta name=Originator content="Microsoft Word 11">
<link rel=File-List href="osstart_files/filelist.xml">
<title>Thank you for choosing Ocean System</title>
<o:SmartTagType namespaceuri="urn:schemas-microsoft-com:office:smarttags"
name="PostalCode"/>
name="State"/>
name="City"/>
name="Street"/>
name="address"/>
name="place"/>
<!--[if gte mso 9]><xml>
<o:DocumentProperties>
<o:Author>Preferred Customer</o:Author>
<o:LastAuthor>chrisl</o:LastAuthor>
<o:Revision>6</o:Revision>
<o:TotalTime>293</o:TotalTime>
<o:Created>2004-05-03T18:21:00Z</o:Created>
<o:LastSaved>2008-01-17T21:06:00Z</o:LastSaved>
<o:Pages>1</o:Pages>
<o:Words>498</o:Words>
<o:Characters>2842</o:Characters>
<o:Company>Dell Computer Corporation</o:Company>
<o:Lines>23</o:Lines>
<o:Paragraphs>6</o:Paragraphs>
<o:CharactersWithSpaces>3334</o:CharactersWithSpaces>
<o:Version>11.6568</o:Version>
</o:DocumentProperties>
</xml><![endif]--><!--[if gte mso 9]><xml>
<w:WordDocument>
<w:SpellingState>Clean</w:SpellingState>
<w:GrammarState>Clean</w:GrammarState>
<w:ValidateAgainstSchemas/>
<w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid>
<w:IgnoreMixedContent>false</w:IgnoreMixedContent>
<w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText>
<w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel>
</w:WordDocument>
<w:LatentStyles DefLockedState="false" LatentStyleCount="156">
</w:LatentStyles>
</xml><![endif]--><!--[if !mso]><object
classid="clsid:38481807-CA0E-42D2-BF39-B33AF135CC4D" id=ieooui></object>
<style>
st1\:*{behavior:url(#ieooui) }
</style>
<![endif]-->
<style>
/* Font Definitions */
@font-face
{font-family:Verdana;
panose-1:2 11 6 4 3 5 4 4 2 4;
mso-font-charset:0;
mso-generic-font-family:swiss;
mso-font-pitch:variable;
mso-font-signature:536871559 0 0 0 415 0;}
/* Style Definitions */
p.MsoNormal, li.MsoNormal, div.MsoNormal
{mso-style-parent:"";
margin:0in;
margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:12.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";}
a:link, span.MsoHyperlink
{color:blue;
text-decoration:underline;
text-underline:single;}
a:visited, span.MsoHyperlinkFollowed
{color:blue;
span.SpellE
{mso-style-name:"";
mso-spl-e:yes;}
span.GramE
{mso-style-name:"";
mso-gram-e:yes;}
@page Section1
{size:8.5in 11.0in;
margin:1.0in 1.25in 1.0in 1.25in;
mso-header-margin:.5in;
mso-footer-margin:.5in;
mso-paper-source:0;}
div.Section1
{page:Section1;}
/* List Definitions */
@list l0
{mso-list-id:1331298651;
mso-list-type:hybrid;
mso-list-template-ids:2085412608 -1540181082 1945659690 -570012458 1013348538 460247218 -1001106514 -1312684192 1427541032 1672374682;}
@list l0:level1
{mso-level-number-format:bullet;
mso-level-text:\F0B7;
mso-level-tab-stop:.5in;
mso-level-number-position:left;
text-indent:-.25in;
mso-ansi-font-size:10.0pt;
font-family:Symbol;}
@list l0:level2
{mso-level-tab-stop:1.0in;
text-indent:-.25in;}
@list l0:level3
{mso-level-tab-stop:1.5in;
@list l0:level4
{mso-level-tab-stop:2.0in;
@list l0:level5
{mso-level-tab-stop:2.5in;
@list l0:level6
{mso-level-tab-stop:3.0in;
@list l0:level7
{mso-level-tab-stop:3.5in;
@list l0:level8
{mso-level-tab-stop:4.0in;
@list l0:level9
{mso-level-tab-stop:4.5in;
@list l1
{mso-list-id:1371344018;
mso-list-template-ids:-454769614;}
@list l1:level1
text-indent:-.25in;
@list l2
{mso-list-id:1641840106;
mso-list-template-ids:-1389320002 702297608 417612094 1819699742 1982738000 788269538 -1848709256 -1799880262 2100309110 741145684;}
@list l2:level1
text-indent:-.25in;
@list l2:level2
@list l2:level3
@list l2:level4
@list l2:level5
@list l2:level6
@list l2:level7
@list l2:level8
@list l2:level9
@list l3
{mso-list-id:1903981468;
mso-list-template-ids:-528166336;}
@list l3:level1
text-indent:-.25in;
ol
{margin-bottom:0in;}
ul
</style>
<!--[if gte mso 10]>
<style>
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
font-size:10.0pt;
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
</style>
<o:shapedefaults v:ext="edit" spidmax="2050"/>
<o:shapelayout v:ext="edit">
<o:idmap v:ext="edit" data="1"/>
</o:shapelayout></xml><![endif]-->
</head>
<body lang=EN-US link=blue vlink=blue style='tab-interval:.5in'>
<div class=Section1>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>Thank you
for choosing Ocean Systems.<o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>&nbsp;<o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>For
technical support, please have your five-digit system serial number available.
It is located on the front of your <span class=GramE>system,</span> If you have
a Luggable then it would be on the left and side of your luggable.<span
style='mso-spacerun:yes'>  </span><o:p></o:p></span></p>
<p class=MsoNormal style='margin-top:5.0pt;margin-right:0in;margin-bottom:5.0pt;
margin-left:0in;mso-layout-grid-align:none'><span style='font-size:14.0pt;
font-family:Verdana;color:navy'>New Downloading Service for Avid Assurance
Customers <o:p></o:p></span></p>
margin-left:0in;mso-layout-grid-align:none'><span style='font-size:10.0pt;
font-family:Verdana;mso-bidi-font-family:Arial'>Avid is pleased to announce a
new software download service. Avid Assurance customers now have the ability to
download software updates over the web. Avid Assurance customers now have 7x24 <span
class=GramE>access</span> to the latest Avid software releases and updates for
their systems!<span style='mso-spacerun:yes'>   </span>Once an Avid Assurance
customer registers for this service, the customer will be notified via e-mail
when a new update is available for their system that is actively covered by an
Avid Assurance contract.<o:p></o:p></span></p>
margin-left:0in;mso-layout-grid-align:none'><b><span style='font-family:Verdana;
mso-bidi-font-family:Arial'>To register for this new service, Avid Assurance
customer can simply go to the following website<o:p></o:p></span></b></p>
mso-bidi-font-family:Arial;color:blue'><a
font-family:Verdana'>All customers who registered will receive a welcome e-mail
message describing the service and a log-on ID and user password. Customers
will eventually have the ability to add new members to their account and update
their own contact information.<span style='mso-spacerun:yes'>  </span><o:p></o:p></span></p>
<p class=MsoNormal style='mso-layout-grid-align:none'><span style='font-size:
10.0pt;font-family:Verdana'>If you have questions about the download process,
please contact <a href="mailto:downloadhelp@avid.com">downloadhelp@avid.com</a>
10.0pt;font-family:Arial;color:blue'>&nbsp;<o:p></o:p></span></p>
10.0pt;font-family:Verdana;mso-bidi-font-family:Arial'>Once on the download
page, you may need to download more then one file to upgrade your system.<span
style='mso-spacerun:yes'>  </span>If the Avid versioner program is required for
upgrading your system, please be aware of the following.<span
style='mso-spacerun:yes'>  </span>This program is periodically updated to
accommodate new Avid Assurance customers. This typically happens on a monthly
basis.<span style='mso-spacerun:yes'>   </span>If the Avid versioner do not
recognize your system for upgrade but you are currently in warranty with Avid
Assurance, please e-mail <a href="mailto:warranty@avid.com"><span
style='font-size:12.0pt;font-family:"Times New Roman"'>warranty@avid.com</span></a>with
your name, location and system ID to get an updated versioner for your
system.<span style='mso-spacerun:yes'>  </span><o:p></o:p></span></p>
<p class=MsoNormal><b><span style='font-size:10.0pt;font-family:Verdana'>Ocean
Systems Hardware or <span class=SpellE>dTective</span> Problems: </span></b><span
style='font-size:10.0pt;font-family:Verdana'><o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>Ocean
Systems<o:p></o:p></span></p>
<p class=MsoNormal><st1:Street w:st="on"><st1:address w:st="on"><span
style='font-size:10.0pt;font-family:Verdana'>4016 Blackburn Lane</span></st1:address></st1:Street><span
<p class=MsoNormal><st1:place w:st="on"><st1:City w:st="on"><span
style='font-size:10.0pt;font-family:Verdana'>Burtonsville</span></st1:City><span
style='font-size:10.0pt;font-family:Verdana'>, <st1:State w:st="on">MD</st1:State>
<st1:PostalCode w:st="on">20866</st1:PostalCode></span></st1:place><span
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>Technical
Support<o:p></o:p></span></p>
<ul style='margin-top:0in' type=disc>
<li class=MsoNormal style='mso-list:l0 level1 lfo3;tab-stops:list .5in'><span
style='font-size:10.0pt;font-family:Verdana'>800-253-7516 Option 3</span> <span
style='font-size:10.0pt;font-family:Verdana'><o:p></o:p></span></li>
style='font-size:10.0pt;font-family:Verdana'>301-476-8015 Option 3 <o:p></o:p></span></li>
style='font-size:10.0pt;font-family:Verdana'><a
href="mailto:support@oceansystems.com"><span style='font-size:12.0pt;
font-family:"Times New Roman"'>support@oceansystems.com</span></a><o:p></o:p></span></li>
</ul>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>If you
are calling after 5:30 EST, please leave a detailed message.<o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>You can
also access support 24 hrs a day via the World Wide Web.&nbsp; Support via the Internet
and email is on a call back basis. Go to the Ocean Systems web page where you
can get access to</span> <span style='font-size:10.0pt;font-family:Verdana'>updated
information and support documents regarding Ocean Systems products.<span
style='mso-spacerun:yes'>  </span>This page also has a support form you can
email.<span style='mso-spacerun:yes'>  </span><o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'><span
<li class=MsoNormal style='mso-list:l2 level1 lfo6;tab-stops:list .5in'><span
href="http://www.oceansystems.com/support">http://www.oceansystems.com/support</a></span>
<span style='font-size:10.0pt;font-family:Verdana'><o:p></o:p></span></li>
</ul>
<p class=MsoNormal><b><span style='font-size:10.0pt;font-family:Verdana'>Avid
Software Problems</span></b><span style='font-size:10.0pt;font-family:Verdana'><o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>Avid
Technology<o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>1 Park
West<o:p></o:p></span></p>
style='font-size:10.0pt;font-family:Verdana'>Tewksbury</span></st1:City><span
style='font-size:10.0pt;font-family:Verdana'>, <st1:State w:st="on">MA</st1:State><span
style='mso-spacerun:yes'>  </span><st1:PostalCode w:st="on">01876</st1:PostalCode></span></st1:place><span
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>800-949-2843<o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'><a
href="http://www.avid.com/onlinesupport/"><span class=GramE>Avid Knowledge Center</span></a><span
class=GramE>.</span> 24 hrs a day<o:p></o:p></span></p>
<p class=MsoNormal><span style='font-size:10.0pt;font-family:Verdana'>If you are
<span class=GramE>a</span> Avid user you can register to this web database
where you can get information by products, categories or search words.<o:p></o:p></span></p>
Assurance</span></b><span style='font-size:10.0pt;font-family:Verdana'><o:p></o:p></span></p>
have Avid Assurance support 8-8pm or 7X24, you can call Avid for answers about
the Avid editing package software functions or issues.<o:p></o:p></span></p>
are unsure which of these options is best for resolving your issues, please
call us at Ocean Systems so we can help direct you. <o:p></o:p></span></p>
<p class=MsoNormal><b><span style='font-size:10.0pt;font-family:Verdana'><span
style='mso-spacerun:yes'> </span><o:p></o:p></span></b></p>
</div>
</body>
</html>
my main rig...
asrock 970 extreme3
antec neo he 650r
PostPosted: Tue Jan 22, 2008 10:00 am
i just tried the file on one of our older xpsp2b boxes, and the activeX warning came up, so it seems most likely it's something to do with the new code. but what?
my main rig...
asrock 970 extreme3
antec neo he 650r
PostPosted: Wed Jan 23, 2008 2:33 pm
well, it took some thinking... but i figured it out that it had to do with the fact that the file was edited in M$ Word, and that that was causing the issue. i re-edited the old file with notepad, and now the warning about active content does not come up.
so... :mb_fixed::
my main rig...
asrock 970 extreme3
antec neo he 650r
