Beginner C++ help
Beginner C++ help
Postby Finalcloud13 » Wed Oct 17, 2007 3:40 am
#include <iostream>
#include <string>
using namespace std;
int main ()
int i, f, m;
string n;
double a = 2.60;
double b = 3.36;
double c = 2.79;
double t;
cout << "Initial meter reading:";
cin >> i;
cin.ignore(100000, '\n');
cout << "Final meter reading:";
cin >> f;
int hcf = f - i;
cout << "Customer name:";
cin >> n;
cout << "Month number (1=Jan, 2=Feb, etc.):";
cin >> m;
if (m == 6 || 7 || 8 || 9 || 10)
if (hcf <= 46)
t = hcf * a;
else if (hcf > 46)
t = ((hcf - 46)*b) + 119.60;
else
if (hcf <= 32)
t = hcf * a;
else if (hcf > 32)
t = ((hcf - 32)*c) + 83.20;
cout << "---\nThe bill for " << n << " is $" << t << "\n";
The problem is in regards to the bolded part. I have the condition only if m is a number 6-10, but any number I input, it still uses the bold code block instead of going to the italicized else block. What am I doing wrong? And, how do I make it that in the underlined output, the number is always shown as a nonnegative number with at least one digit to the left and exactly two digits to the right of the decimal point?
Also, I'm not understanding too well why I don't get an error for using double, but I do for float. I thought float could be used for decimals too.
Please point out any mistakes in the code or anything that is not needed yet included in there. Thanks in advance.
Finalcloud13
Postby Roach412 » Wed Oct 17, 2007 7:59 am
why have all those ORs?
why not just use if( conditionA && conditionB ) like
Code: Select all
if( m > 5 && m < 11)
as for the formatting portion - it's actually pretty simple, but you'll need to discover that on your own. this is a really simple example of what you're looking for - you should have a book or reference for which to find the same info:
http://www.arachnoid.com/cpptutor/student3.html
what error are you getting when using float?
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
Roach412
Postby Finalcloud13 » Wed Oct 17, 2007 1:05 pm
Thank you, it worked nicely. And slash the part where I said double gave errors, it doesn't anymore.
Finalcloud13
Return to Programming
