It is currently Thu May 23, 2019 9:12 pm
 Post subject: SQL Scripts for Newbies
PostPosted: Mon Jul 23, 2007 10:09 am
I know nothing about SQL other than the fact that my peers occassionally provide me with a SQL script to run against our databases. I would like to learn how to write these scripts against our database and I am looking for a Novice level tutorial to get me started. Can anyone advise?
Antec 900 - 650W ATX
Intel DQ35JOE
MS Windows 10-64bit
PostPosted: Tue Jul 24, 2007 9:28 am
http://www.w3schools.com/sql/default.asp
PostPosted: Tue Jul 24, 2007 9:35 am
what kind of database do you operate?
-Roach
Crucial M4 256gb SATAIII SSD
Logitech G930 7.1 Headset
DBPOWER RGB LED Keyboard
Logitech G402 Hyperion Fury
PostPosted: Wed Jul 25, 2007 10:40 am
it is a script run against oracle
Intel DQ35JOE
MS Windows 10-64bit
PostPosted: Wed Jul 25, 2007 11:46 am
i found a SQL for Dummies book a while back that was actually pretty good... you should be able to get one at any large-sized book store, or computer specialty shops.
the above page is pretty helpful for really basic info, but if you want to understand more specifically to oracle instances you'll want to get an oracle book about queries and perhaps PL/SQL...which i find to be the most fun to work with.
-Roach
