It is currently Sun Mar 24, 2019 10:26 am
 Post subject: realtek lan driver
PostPosted: Fri Nov 26, 2004 8:32 pm
I have updated to the latest lan driver from
http://www.realtek.com.tw/downloads/dow ... tware=True
But everytime I try to connect to another computer I get a BSOD with error code 1000008E, {c0000005, 8244c8b, ee4e1fb4, 0}
where can I get previous versions of the driver, 6.18 is the latest. I have a gigabyte nforce2 ga-7n400 motherboard with realtek 8110s lan I think :?
PostPosted: Fri Nov 26, 2004 8:38 pm
Use the drivers from Gigabyte:
http://www.giga-byte.com/Motherboard/Su ... -7N400.htm
PostPosted: Fri Nov 26, 2004 8:50 pm
no lan drivers only nvidia chipset, usb and audio.
PostPosted: Fri Nov 26, 2004 8:56 pm
the GA-7N400 has no onboard lan, so which version have you?
is it the GA-7N400 Pro? drivers here
PostPosted: Fri Nov 26, 2004 10:18 pm
i have a ga-7n400 with a realtek 8139/810x lan. It use to work but after a BIOS update and a windows re-install it keeps crashing. I don't think the latest driver works with sp2 :roll:
PostPosted: Fri Nov 26, 2004 11:19 pm
there are 14 different boards with GA-7N400 in it........you need to make sure which board it is, and maybe you flashed the wrong bios to it?
there is:
GA-7N400
GA-7N400Pro
GA-7N400Pro2(rev 1.0)
GA-7N400Pro2(rev 2.0)
GA-7N400E
GA-7N400E-L
GA-7N400-L my guess is this one
GA-7N400-L1
GA-7N400S
GA-7N400S-L
GA-7N400V
GA-7N400V Pro
GA-7N400V Pro 2
GA-7N400V-L or this one.
the regular GA-7N400 has no onboard lan.....so which model do you have?
here is the link for the realtek 81xx driver, for XP/2000/ME and 98.
