It is currently Wed Apr 24, 2019 2:11 am
PostPosted: Fri Nov 19, 2004 11:22 pm
Im trying to network 2 computers at home using crossover cables.
One is running XP Professional 'n the other 98SE.
I wont be able to share the internet coz theres just 1 NIC on this machine so it can be either used for internet or networking the 2 pcs.
I followed this link to network the 2 of them.
http://www.homenethelp.com/web/howto/net.asp
Since Im not going to use the net I'll have to put in static IP in both of them which I put as 192.168.10.100 on this machine and 192.168.10.101 on the other one and subnet mask as 255.255.255.0 in both the machines.
I also put them in the same workgroup and i also enabled NetBios over TCP/IP in Xp.Now the problem is that in 98SE in the Network Neighborhood I can see that machine itself but not XP and in My Network Places in XP there r no machines in the workgroup computers.
Also when I ping from 98SE to XP I get proper response but its not the same case vice versa.In 98SE when I type the command "net view" it only shows that computer in the workgroup.I've also disabled the firewall and checked the crossover cable thoroughly.
I face the same problem when I use the Network Setup Wizard in XP to set it up for networking.
One more thing I forgot to mention is that I havent installed any SP on XP.
Plz help.
Also I would appreciate if you can insert some links
to other Windows networking forums which u know.
Khotwadi.
PostPosted: Sun Nov 21, 2004 2:23 am
Have you shared any drives, folders or printers on the XP machine?
Aussie
PostPosted: Tue Nov 23, 2004 3:07 am
Yes I've shared quite a few folders on both comps.
But i forgot to mention that i dont have any SP on
my XP machine.
Khotwadi.
PostPosted: Thu Nov 25, 2004 6:47 am
Test 1
Can you ping from the w98 PC to the WXP PC?
Test 2
Can you ping from WXP to w98 PC?
Test 3 (Assuming both ping test are working)
From W98 PC, start, run, \\IPaddress of XP PC
Do you get anything from Test 3?
[/url]
 Post subject: Networking 98 & XP?
PostPosted: Thu Dec 02, 2004 8:59 pm
Are you using NetBEUI? 98 is kinda network dumb.
J X Doe # 1524
Asus/AMD 2.3gHz
2x WD HDD 40/80Gb
w/Floppy!
PostPosted: Fri Dec 03, 2004 9:20 am
You may not need NETBEUI if you can modify the lmhosts
[/url]
