It is currently Tue Mar 26, 2019 3:00 pm
 Post subject: wireless router
PostPosted: Tue Nov 16, 2004 7:20 pm
I am setting up a two computer network including one desktop and one laptop using wireless. The desktop is using an ethernet cable to connect to the linksys wrt54g wireless router. The cable service is not available right now but should come back by tomorrow.
My question is should the lack of an internet connection cause the 2 machines not to see each other on the network because they can't. The router has yet to establish an internet presence. I have verified that windows identifies the network hardware on both machines.
Any ideas?
 Post subject: Re: wireless router
PostPosted: Tue Nov 16, 2004 7:57 pm
Any ideas?
What are the OSes? Can either machine ping one another and are both in the same workgroup? Secondly, the master browser PC needs to turned on for a while for both machines to actively participate in the workgroup environment
[/url]
PostPosted: Wed Nov 17, 2004 1:05 am
Try setting up an "ad-hoc" network, until you get the connection going, just to check the hardware out.
But if the "inside" of the router (the wirelless access point) is set up properly you should not have a problem. Never used that particular router, but at work we've used 2 different DSL modem/WLAN router combo units, and even if theDSL was down, the wireless notebooks would still print through the print-server (PC hooked to the router/switch via Ethernet cable)
P3! (No, not PIII)
PostPosted: Wed Nov 17, 2004 3:42 am
one is xp home and one is xp pro. I didn't do a whole lot of troubleshooting as I'll be back out there tonight. Both are part of the same workgroup.
PostPosted: Wed Nov 17, 2004 9:46 am
Oh to answer your question about the router, no it doesn't have to have an internet connection for the two machines to talk
[/url]
PostPosted: Wed Nov 17, 2004 9:51 am
I'm starting to think it is the laptop. After I left there cable internet came back and the desktop gets to the net fine. The laptop didn't
PostPosted: Wed Nov 17, 2004 9:53 am
Maybe bad NIC or worm or virus... sounds like maybe too much chattering
[/url]
PostPosted: Fri Nov 19, 2004 4:24 pm
Check your wireless security settings. Make sure the MAC address of the laptop is allowed.
