Windows XP Professional won't allow complete file sharing
Postby Ghen » Fri Sep 24, 2004 4:59 pm
I'm trying to share -everything- on an XP Pro machine with both another XP Pro and a XP Home machine. Thing is, Pro doesn't allow sharing of 'Program Files' and indivudual user folders in the 'Documents and Settings' folder.
What gives? I want all my save games and documents easily transferred without wasting a CD.
sharing document by microsoft
Note this paragraph:
Note The Sharing option is not available for the Documents and Settings, Program Files, and Windows system folders. In addition, you cannot share folders in other users’ profiles.
Ghen
Postby J.C.GARCIA » Fri Sep 24, 2004 9:12 pm
just a thought but have you tried draging or copy/pasting those folders to the shared documents folder :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
J.C.GARCIA
Postby snap355 » Mon Sep 27, 2004 1:04 pm
Also try turning simple file sharing option.
snap355
Postby donut » Wed Sep 29, 2004 7:25 pm
Try also creating another folder, perhaps under the root directory, and sharing it. Check your permissions and allow the user "EVERYONE" at least full read access. You may also need to look at the Security tab which is next to the sharing tab, and also define the user "EVERYONE" as having read access.
donut
Postby dr_st » Thu Sep 30, 2004 2:23 am
IIRC, the way I solved this problem was by temporarily disabling simple file sharing (Tools -> Folder Options -> View -> Advanced Settings) and setting some manual permissions for the aforementioned folders. Once I saw that it worked, I turned simple file sharing back on.
dr_st
Postby snap355 » Thu Sep 30, 2004 7:21 am
I would permanently turn off simple file sharing. Just like how most people like to custom build their PCs because of options and control, it's better to control the security on your PC yourself and gives yourself more options if you have multiple users.
snap355
Postby Ghen » Sat Oct 02, 2004 9:07 am
sorry about the late reply but this is a good update.. I didn't know about the simple file sharing switch, so I looked for it and actually found it unchecked.
So I checked use simple file sharing, then shared the folder I wanted, and now I can see it.
Ghen
Postby snap355 » Mon Oct 04, 2004 8:40 am
At least it's fixed. :lol:
snap355
Return to Networking
