It is currently Tue Aug 21, 2018 10:06 pm
PostPosted: Wed Sep 22, 2004 5:35 am
I have my router feeding internet access to my wireless laptop and to my wired desktop. Now the problem is i dont know how to set up so i can have a network and send files and share printers and such. Can anyone offer any help?
Greg
PostPosted: Wed Sep 22, 2004 12:20 pm
What is the operating system on each machine?
PostPosted: Wed Sep 22, 2004 12:43 pm
On the desktop it is xp pro and on the laptop it is xp home edition, the router is the belkin f5d7630. Hop that helps
Greg
PostPosted: Wed Sep 22, 2004 5:18 pm
Its fairly simple in those operating systems.
Check to make sure File and Printer Sharing is enabled. Go into Network Connections, right click on the LAN connection and choose Properties. Make sure File and printer sharing is in the List and checked.
From Control Panel, go into System and from Computer Name, make sure you are both on the same workgroup, but have different computer names.
You should be able to share files, folders and printers now.
Network Places should display the PCs in your network.
To share a printer, right click the printer and choose Sharing.
To share a folder, right click the folder and choose Sharing and Security.
Should work.
PostPosted: Thu Sep 23, 2004 12:37 pm
Make sure to turn off any internet firewalls you may have.
