It is currently Sat Sep 22, 2018 6:00 am
PostPosted: Sat Sep 18, 2004 10:39 am
hello all, i have installed the free version of zonealarm, i have looked at the control panel and it is reporting having stopped 750 access attempts on the inbound protection. is this normal?
thanks for looking
jake
MSI K8T800
amd Athlon 4000+
2gig DDR
500gb Hitatchi SATA
80gb max PM
Pioneer 115D PS
ATI x1650
PostPosted: Sat Sep 18, 2004 10:54 am
Unless there is something there specifically worrying, I would say that sort of quantity if perfectly normal.
Friends have told me that everytime they login to Hotmail or MSN they get an alert that M$ is trying to gain access. This is probably a "Product Key" check on Windows or something. So they have an archive of thousands of alerts.
PostPosted: Sat Sep 18, 2004 11:09 am
yeah sounds normal to me, you could look throught he logs and stuff to find out what it is or where it is comning from, such as a website, another comp or person trying to connect, cookies can sometimes do it, java or activeX controls can as well
I wouldn't worry about it much since they are being blocked until somehting weird starts happening to your comp to make you think its been compromised
P4 3.2 Prescott LGA-775
X600Pro PCI-E (not the best but cheap and decent)
Gigabyte GA-8I915P Duo-A
Geil UltraX 2-2-2-5 1gig Dual Channel
PSU
http://www.xpcgear.com/jaguar450psu.html
28a on the +12v
PostPosted: Sat Sep 18, 2004 5:51 pm
Your internet service provider might try to contact your PC as a part of its normal routine - we have a cable company up here that does the came thing on the cable internet service.
You can recieve tons of useless traffic a day
PostPosted: Sun Sep 19, 2004 3:11 am
Lol on mine:
42942 Intrusions have been blocked since install
2342 of those have been high rated
I've only had it installed a few weeks too
PostPosted: Sun Sep 19, 2004 3:12 am
And as I typed that I got another 3 blocked
PostPosted: Sun Sep 19, 2004 5:50 am
Keep in mind there are several programs like blaster and other junk rolling around on the net.
In our college network, we estimated the average survival time of an unprotected PC on the network at 20 mins max.
Users browsing this forum: Istellabot [Crawler] and 1 guest
