It is currently Thu Sep 20, 2018 8:39 pm
 Post subject: Wireless
PostPosted: Fri Sep 17, 2004 12:37 am
Finally went out and bought my wireless network... all D link gear with a router Airplus Xtreme G 802.11g at 108Mbps. Two wieless ports, one a laptop and one for the other comp. Total cost $NT7200 which is USD about $218. I think this is a good price. I'll post later when I get home and report on the assembly.
PostPosted: Sat Sep 18, 2004 2:03 am
A seamless network, but the adls connection is not working. A bit of a mystey as yet but as I will be away for 10 days, will finish later.
PostPosted: Sat Sep 18, 2004 5:53 pm
The connection should be set dynamically in the router - there shouldn't be any issues.
PostPosted: Sat Oct 02, 2004 7:54 pm
Finally have time to look at this. The adsl connection doesnt want to work. The installation data said to uninstal the ppoe connection which I have done, but I am unsure what I can do next. I am running W2K. Any suggestions?
PostPosted: Sat Oct 02, 2004 10:03 pm
Well we have to start at the router first. Is the router configured for PPPoE and connecting properly? The status are should display a proper IP address.
PostPosted: Sat Oct 02, 2004 10:09 pm
You have identified the problem with precision. This reply is from the router so many thanks.
Actually I was hoping to give a blow by blow description of the process but it has ended up being much easier than I thought. Plug in (read manual) follow thw wizard and there it is
PostPosted: Sat Oct 02, 2004 10:20 pm
Good to hear all went well./
