It is currently Wed Sep 19, 2018 11:04 am
 Post subject: wireless through walls
PostPosted: Thu Sep 16, 2004 1:44 pm
i posted this a while back and believed it was deleted , think it was the beginning of this forum . can a wireless modem transmmit through a concrete wall :?: . its the only thing that is stopping me from switching from dialup to adsl :evil:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
radeon 7000 64mb w/tv out
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Thu Sep 16, 2004 5:12 pm
Depends how think the concreate but yes it can.
You might want to look into 802.11a technology (which is stronger) if the walls are extremely thick.
You can also purchase addition access points to extend your range.
PostPosted: Thu Sep 16, 2004 5:16 pm
i dont want to sound stupid and i know i will , but were are the access points connected to :?:
p4 2.4b 533mhz fsb
epox 4bea2
768mb ddr pc2100
live 1024
dvdrw lg gsa 4040b
cdrw btc 48x16x48x
xp home
PostPosted: Thu Sep 16, 2004 5:25 pm
Access Points would extend the range of your wireless network. Or you could just use a wireless range extender.
Plug them into the wall for power, and configure them to attach to your network and you are set.
PostPosted: Thu Sep 16, 2004 6:55 pm
The range extenders do not need to be connected to a computer. They just plug into a power outlet like HJ said. They pick up a signal, clean it up a little (I think), amplify it , and rebroadcast.
PostPosted: Sat Sep 18, 2004 5:48 pm
They do filter out noise.
