It is currently Wed Aug 21, 2019 2:06 am
 Post subject: Wireless Question
PostPosted: Wed Sep 15, 2004 3:59 am
What would cause a "running perfectly well wireless system_one wired two wireless_ for six months" to all of a sudden not work for 6 hours. The wired worked of course but neither wireless system? Hacking? I am using MAC addresses. Something else?
Thanks.
PostPosted: Wed Sep 15, 2004 4:54 pm
Just 6 hours and then go back to normal?
 Post subject: Yup
PostPosted: Wed Sep 15, 2004 5:48 pm
Sunday 3:00 pm till approx 9:00pm. All of a sudden started working again.
Asus P4P800 Deluxe
Pentium 4 @ 3.0 ghz
Ultra 3200 DDR 512mb x 2
S B Live 5.1
ATI Radeon 9800 Pro
Win XP Pro sp 2
PostPosted: Wed Sep 15, 2004 5:55 pm
If you are still running with the original username/password combination that came with the router, I would suggest updating it ASAP.
Do you use WEP?
PostPosted: Wed Sep 15, 2004 6:10 pm
I don't use the user/pass that came with it. I have my own.
Yes i use wep.
Asus P4P800 Deluxe
Pentium 4 @ 3.0 ghz
S B Live 5.1
ATI Radeon 9800 Pro
Win XP Pro sp 2
PostPosted: Wed Sep 15, 2004 6:26 pm
Switch to SSH if practical.
Both MAC filtering and WEP can be sniffed out with sufficient number of packets.
P3! (No, not PIII)
PostPosted: Wed Sep 15, 2004 6:46 pm
That would take weeks, maybe even months before the right packets are found.
Did you try moving the wireless devices closer or to different areas?
Was the signal completely dead? Are you using the Windows manager or program client included with the wireless device?
PostPosted: Thu Sep 16, 2004 8:18 pm
What's ssh?
Anyway I am using windows to manage my connections, and the little icon said "little or no connectivity".
PostPosted: Thu Sep 16, 2004 11:07 pm
That sounds like RF issue then. Did someone do some works and use PRS (CB)? A new radio/cellphone tower put up recently in the neighbourhood? Cordless phone? I can't think of what else would cause that, but smells like RF issue.
BTW SSH is Secure Shell, encryption technique considerably more resilient to hacking, but tends to slow down large networks. Also requires support by the router.
P3! (No, not PIII)
PostPosted: Sat Sep 18, 2004 5:47 pm
Just to throw something in - I can't really tell what happened to cause your problem, especially since it magically fixed itself.
But I recommend using a config utility bundled with the wifi card instead of the Windows network config.
DLINK, LINKSYS, etc all come with them.
