It is currently Thu Sep 20, 2018 9:06 am
Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Sep 16, 2004 9:20 am
Hardware Junkie wrote:
Mostly correct in all cases.
With #3 - "If you DO have multiple external IP addresses and you want the same port open on all, you have the following options"
Sorry. That was obviously what I meant, but I forgot to make it clear.
PostPosted: Thu Sep 16, 2004 5:05 pm
That's what I figured - just wanted to make it clear for anyone else watching the thread.
PostPosted: Fri Sep 17, 2004 12:31 am
Which is the right thinking. Hence my apology to the rest.
PostPosted: Fri Sep 17, 2004 6:51 am
At one point when I was using a Switch setup instead of a router with DSL, I was able to make an internet connection on each machine..
could a switch be used with a cable connection and be able to connect 2 or more pcs at the same time to the internet? I too have used a switch with dsl but not cable.
PostPosted: Sat Sep 18, 2004 5:59 pm
I think in this case your internet service provider would help you out.
I was running with a switch on the Rogers cable internet service up here. But when we attached to the network, each computer had a different Computer Name (10 bucks extra per month per computer).
And it worked fine.
Depending on how the cable internet is setup. Just attaching a switch in between the systems and the cable modem might give internet access to all systems.
