It is currently Sun Feb 17, 2019 12:24 pm
 Post subject: hub help
PostPosted: Wed Sep 01, 2004 12:18 pm
quick help please.. i've got to give a cable modem connection to two pc's, how would I do it with this
http://www.mysale.ca/sales/30524.html
Ok, the modem has a ethernet port and a usb connecter type also, how would i use that hub, this modem and to connect both systems. both are on xp, and both have a free usb or a free lan ethernet if needed.
does this hub connect to the modem using the usb connecter, or a lan cable? or does the hub connect to the pc;s using some usb cable, or a usb.
also, if it fails, how would i setup an ICS for both xp pc's, we have two spare pci ethernet if needed
Cele 1.8ghz
1gb SD100
ati radeon 9200se
sb live 5
PostPosted: Wed Sep 01, 2004 1:28 pm
That's a hub to split up your USB ports. What you'll need to connect 2 computers to one connection is a ROUTER.
