Networking Power Problems
Postby Ad Harwood » Sat Aug 28, 2004 1:30 pm
Ive put 2 Computers into a direct network - no hub or anything - just a cable. Problem is whenever I power down on my one computer my other one starts up again. This does not happen the other way around though!!!
It may be because i am using an ICS connection - i dont know.
Ad :o
AMD Athlon 2.2ghz
2700 512mb
Nvidia Geforce FX 5200 AGP
100gb Harddrive
Win XP SP1
Ad Harwood
Postby Copper » Sat Aug 28, 2004 1:34 pm
what cable are you using to connect the two
Copper
Postby Ad Harwood » Sat Aug 28, 2004 1:39 pm
Just the usual RJ 45 cable from one computer to the other
Ad :lol:
AMD Athlon 2.2ghz
2700 512mb
100gb Harddrive
Win XP SP1
Ad Harwood
Postby Copper » Sat Aug 28, 2004 1:42 pm
Ad Harwood wrote:Just the usual RJ 45 cable from one computer to the other
Ad :lol:
you need a cat5e cross over cable
Copper
Postby jato oswor » Sat Aug 28, 2004 1:42 pm
Are you using a built in LAN plug or is it a PCI card. Also are you using WOL.
big burning heap of metal shards and lumps of plastic
jato oswor
Postby Ad Harwood » Sat Aug 28, 2004 1:44 pm
Well maybe i need that cable but the network does work fine. Im using a PCI card but mot with WOL
Ad :?
AMD Athlon 2.2ghz
2700 512mb
100gb Harddrive
Win XP SP1
Ad Harwood
Postby kokalo » Sat Aug 28, 2004 2:23 pm
Ad Harwood wrote:Im using a PCI card but mot with WOL
On both ends? Because it certainly sounds like WOL issue. If one of the NICs is O/B and WOL is not disabled in BIOS, it would explain the issue showing one way around but not the other.
Even if they ar both PCI, actually, but then it would be configured in NIC BIOS, not PC one.
P3! (No, not PIII)
kokalo
Return to Networking
