Multiple Printer Print Server
Postby risoftwi » Thu Aug 12, 2004 1:06 pm
Does anybody know of a print server, router combo that allows multiple printers to be connected?
Edit: The printer ports would have to be USB
risoftwi
Postby Hardware Junkie » Thu Aug 12, 2004 2:51 pm
I don't think there is a commercial grade router with more then 1 Print Server built in.
You can get separate print servers with more then one port.
For example:
http://www.dlink.com/products/?pid=336
Postby risoftwi » Thu Aug 12, 2004 3:31 pm
Thank you. I guess I just want to stay away from the wireless solution, but it doesn't hurt to try it out.
risoftwi
Postby Hardware Junkie » Thu Aug 12, 2004 3:44 pm
DLINK has a wired solution, but its 2 parallel port printers and 1 usb.
I am sure that will change, but for now the wifi solution is the best choice.
Postby risoftwi » Thu Aug 12, 2004 3:59 pm
Yeah I guess I can just set-up printer sharing on one system and then get a print server later on down the road. Either that or I can pick up a couple of the USB to Parallel adapters. I don't know. I guess all is well for the time being.
risoftwi
Postby Hardware Junkie » Thu Aug 12, 2004 4:11 pm
USB to Parallel adapters may not work on printer servers
Postby risoftwi » Thu Aug 12, 2004 4:13 pm
Well I guess I'll just scrap the whole project for now and buy a new TV, or CPU parts one of the two.
risoftwi
Return to Networking
