CAT5-->CAT6 Network trouble
Postby asfMX » Tue Aug 10, 2004 3:00 pm
Im setting up my friends network. Im using an linksys cable/dsl router. I was able to get his old computer to see the router in seconds. When I go through the wizard to setup the connection on his new computer it does nothing. It finishes and I see no new connection. Just "1394 connection".
All of the cable running from the router to the old computer is CAT5. The cable running to his new computer is CAT6, Im wondering if it is the CAT6 that is causing the problem or could it be the new computer?
I built his new computer and am plugging the cable into the port on the motherboard (IC7 max 2), could I of possibly done something to it? Should I try an ethernet PCI card?
Thanks,
-asfMX
asfMX
Postby Hardware Junkie » Tue Aug 10, 2004 3:05 pm
Cat 5 and Cat5e/Cat6 will work fine together.
If the board has onboard ethernet, it doesn't sound like the drivers are installed properly.
Postby asfMX » Tue Aug 10, 2004 3:07 pm
Thank you.
Ill try that tomorrow.
asfMX
Postby kokalo » Tue Aug 10, 2004 10:44 pm
Is it enable in the BIOS to start with?
If so, check under H/W manager if it shows or not - which would indicate whether the drivers are installed properly and if the NIC is going (small chance, but it could actually be faulty).
P3! (No, not PIII)
kokalo
Postby asfMX » Wed Aug 11, 2004 7:09 am
It was the drivers, thanks guys.
asfMX
Return to Networking
