It is currently Sat Oct 20, 2018 1:37 pm
PostPosted: Thu Aug 05, 2004 3:22 am
Okay I've been looking to add a wireless print server to add to the network, and mostly what I been coming up with are been silly USB things. I have a truly magnificent piece of printing technology (okay it does @#$! up occasionally but not enough to be worth getting rid of), a HP LaserJet 4L. It's quite obviously not USB. So would it work to get a USB-parallel adapter for the print server? (Yes I know that LinkSys make ones which also attach to parallel but they're rather expensive and harder to find in shops.)
The other question is how a slower device affects the network. If I were to use an 11b print server on an 11g network, would the whole network communicate at 11b or would the machines communicate at 11g, and only talk to the printer/print server at 11b? In which case, printing packets are small enough that 11b would be fine if I can find it in parallel. Otherwise, my first question also still applies.
Thanks for all the expertise guys! The more I learn, maybe I'll be able to help somebody else out in future (and to think that when I saw the new forums, I thought "Networking? Pah! I'll never need to go in THERE!"...
PostPosted: Thu Aug 05, 2004 2:21 pm
I am not sure that is going to work. The idea of the parallel to USB adapter is that Windows would recognize the change, but going from Parallel to USB to Print Server might not be compatible
I'd stick with what works.
http://www.dlink.com/products/?pid=174
If you really have trouble, let me know and I can get one for you and ship it out.
The devices attached to the WIFI connection work like a port on a switch, direct connections to each device. There will be a bottle neck to the printer, but it won't affect speed between PCs.
Doesn't matter much, your HP doesn't have a super fast PPM anyways.
