Router network lag
Postby Roach412 » Tue Aug 17, 2004 4:37 am
what i mean with spiking is this:
you're playing and doing fine at your 40(or whatever) ping then it jumps to 300+ for a second or two and then returns to normal.
by continual lag i mean this:
if you have only your computer on the router you are getting 40(or whatever) ping, but when you connect any computers your ping is constantly at a 'bad' level.
spiking typically means a bottleneck someplace, and more often it's the connection.
what kind of bandwidth are you using up/down?
and importantly, what kind of game(specifically) are you playing?
Return to Networking
