It is currently Sat Sep 22, 2018 11:23 am
 Post subject: USB Wireless for XP
PostPosted: Wed Nov 16, 2016 8:03 am
I want to replace my old PCI wireless network card with something that is better.
I would prefer a USB type application.
There is no gaming needs, just the ability to connect to my WIFI router at a reasonable rate of speed.
I am looking for suggestions to avoid purchasing something inadequate.
I am on XP OS.
One that I recently looked at is:
EDUP Wifi Adapter 300Mbps Wifi Dongle 2.4GHz Wireless USB Adapter with High Gain Antenna
Any thoughts on the one I mentioned? It only costs $13.
Any and all recommendations greatly appreciated.
Antec 900 - 650W ATX
Intel DQ35JOE
PC2-6400 DDR2-SDRAM UDIMM - 2x2 GB (Clocking 400mhz)
Primary: SATA 3gb/s - Hitachi HDP725050GLA360(500 gb)
External-USB: SATA 3gb/s - WDC-WD7500AACS-00ZJB0 (750 gb)
Microsoft Windows XP Professional Build 2600 - SP-3
 Post subject: Re: USB Wireless for XP
PostPosted: Sat Nov 19, 2016 2:40 am
That one will work, XP is supported. Bear in mind if your routers wifi is only a/b/g then you won't get the maximum of 300mbps, but at most about 50mbps.. If your router is wifi n compatible, you will get a maximum of about 150mbps (if you are lucky). If your router is wifi n then you will get 300mbps (full THEORETICAL speed)..
