Getting Disconnected From DSL Internet
Post Reply
c327
Post by c327 »
This PC:
New laptop with Windows 10 Pro x64
Internet: 6.0 DSL laptop connected via ethernet cable from wireless AT&T (Netgear 7550) router.
Internal wi fi Intel AC7260 AC+BT
Having an issue with getting disconnected from the internet. This never happened before prior to getting this new laptop. I can be using the laptop on a website fine and after a short while go to another website and it won't connect. I check and see that I am no longer connected. I run an internet checking utility and it says Default Gateway Is Not Available. It does a self fix and corrects what ever is wrong and then later in the day it will happen again. Sometimes all I need to do is reboot and it corrects itself.Also noticed sending some emails via Outlook 2016 seem to take very long to send.
What seems to be wrong here ?? Could it be the router not being set up correctly with this new 64 bit Windows 10 system ? or is it something with the laptop ?
Note:
I may have been using just battery power at the time (don't remember) but still connected to wireless router via Ethernet cable if that makes a difference.
I'm going to delete the Ethernet Controller Driver and let Windows install what is needed and see if that works ???? If it does I will see if I can get the correct drivers
Thanks..............
KEEP AMERICA GREAT
Re: Getting Disconnected From DSL Internet
Post by Mr T »
Go in to control panel (right click on the windows left corner logo and select control panel).. Go to power options and open it up. at the 'Coose or Customize power plan' select 'Change Plan settings' for the current plan (circle with black dot in centre). At the next screen click on 'Change advanced power settings'. A power options box ill pop up, go down to PCI Express Settings, click on the + symbol to expand and expand 'Link state power management'. Where it says setting switch it to 'Off'. Click on Apply, then the - symbol to close them down. Stay in this and move up to 'Wireless Adaptor Settings' and under 'Power saving mode' set it to maximum performance. Apply, close down and reboot the laptop.
This should stop windows sending the lan and wifi card to a sleep state - I had annoying disconnects a lot until I switched Link state power management to off and it has just stopped, it also stopped video play esp on facebook freezing the whole system up...
(Yes another windows 10 annoyance, but at least the fix worked for me, hopefully it will for you)...
Post Reply
