It is currently Thu Oct 17, 2019 12:38 pm
 Post subject: Laptop wireless Adaptor
PostPosted: Sun Sep 13, 2015 9:06 am
I have a Compal JHL90 laptop that is 7 years old and still works good except Windows 10 64 bit will not work on it because of some of the installed hardware. The CPU is 64 bit ready and will work. The Intel 5100 wi fi link is not compatible according to Intel. Where is this wi fi adaptor located in this JHL90 laptop and can it be replaced with something that will be compatible with Windows 10 64 bit. I am wondering what other hardware might not be compatible with Windows 10 64 bit.
I really would like to keep this laptop if it wouldn't be a big deal upgrading what ever needed to be upgraded, drivers included. I looked on Compals website and see no drivers available for this model PC and Sager has no information on it any longer.
The wi fi adaptor is my first concern because with out it the PC is useless to me. I have a brand new unopened CD with Windows 10 Pro 64 bit with the COA and don't want to ruin it on something that will not fly.
MAKE AMERICA GREAT AGAIN
PostPosted: Sun Sep 13, 2015 4:29 pm
That laptop is part of the Sager family?
Normally, the Wifi antenna is wrapped around the screen in the lid.
A quick search turned up this link showing the antenna and interface units..
http://www.ebay.com/itm/OEM-15-4-INTERN ... 235797ffc3
Should be easy to find, on opening the case.
But maybe hound Sager about drivers for the feature first?
Then there is this..
http://answers.microsoft.com/en-us/insi ... a37?auth=1
http://www.driverstools.com/sager-drive ... -xp-vista/
PostPosted: Wed Sep 16, 2015 9:13 am
Two ways to do this, the WIFI card is either under the large access cover or the small one next to the hard drive access case. You can simply replace the old card with a new compatible one (I recommend getting one that supports wifi AC). The antennae won't need replacing. The other option is to get a USB one.
PostPosted: Fri Feb 19, 2016 12:55 pm
This issue is happening not in wi fi mode. The laptop is connected to the router via Ethernet cable.
PostPosted: Fri Feb 19, 2016 12:57 pm
This problem is happening when the laptop is connected to the router by a Ethernet cable. Wi Fi is not being used.
PostPosted: Fri Feb 19, 2016 1:14 pm
Hi,
The wi fi card is AC 7260 AC+BT what ever that is. This is a brand new laptop with the upgraded wi fi card ???
The laptop is connected to the wireless router via an Ethernet cable. So I guess the antenna should not have anything to do with this? Oh just thought of something. The original screen was changed by Sager and replaced with a IPS screen I think it was. I am not using the computer on wi fi.
PostPosted: Fri Feb 19, 2016 8:09 pm
From reading your first post it looked like you wanted to switch out your WiFi card to one which has driver support for Windows 7 64bit. From reading your last two posts it would appear you have some kind of other problem you would like to fix, but it is not clear what that is - maybe something to do with no network connectivity after installing windows 10 64bit?
If you haven't installed win10 yet and want to check what hardware is or is not compatible then microsoft's official tool would be a good place to start https://support.microsoft.com/en-us/kb/3035583
Bear in mind if you have only 2GB ram then win10 32bit is probably a better option - it has smaller install size and runs quicker on systems with 2GB ram.
