It is currently Thu Oct 17, 2019 5:04 am
PostPosted: Sun Apr 10, 2011 4:41 am
Running 2k on a older Laptop, running the manufactures (Ralink RT2870 chipset) utility for a USB wireless stick causes issues so I want to try using Windows wireless utility. Problem is, I can't find how to use it. I have it running under Services.
The supplied utility & drivers are installed, but I stopped loading the utility since it causes the PS2 mouse to stop responding as soon as the utility loads. The stick connects and does work, but I have no control over it without running the utility.
I tried another no name sticks software (the exact same stick, but under a different name) but it has a overly complex utility (and a newer driver), but it causes the Laptop to lock up completely.
I never used a USB wireless stick before and never used wireless anything in 2k when I use to run it 6 or 7 years ago. The Laptop isn't for me.
Does 2k have the ability to run a wireless device with its own utility as it does in XP, or is this because it is a USB stick, not a PCI card where the problem is?
PostPosted: Sun Apr 10, 2011 5:18 am
http://www.ohlone.edu/org/infotech/wire ... s2000.html
