It is currently Sun Jan 20, 2019 1:05 am
PostPosted: Sun May 02, 2010 9:53 pm
Problem: Cannot connect to the internet (either a router or computer program, that's what i'm here to find out) :P
Also, it doesn't seem to recognize any wireless connections either. I sometimes uninstall my network adapter, restart my computer and let the network adapter reinstall. This worked the first few couple of times.
However, it stopped working.
When i open cmd.exe and type in ipconfig, i notice that it has a different ipaddress, my current (working) one displays
(working) displays:
ipv4 address: 192.168.2.2
subnet mask: 255.255.0.0
default gateway: 192.168.2.1
laptop (not working) displays::
autoconfiguration ipv4 address: 169.254.34.136
i do notice it says "autoconfiguration ipv4", could it be there's something in need of a change?
also, i took my time to make a whois check up on the ip, weird stuff. . .
http://cqcounter.com/whois/
Quote:
OrgName: Internet Assigned Numbers Authority
OrgID: IANA
Address: 4676 Admiralty Way, Suite 330
City: Marina del Rey
StateProv: CA
PostalCode: 90292-6695
Country: US
NetRange: 169.254.0.0 - 169.254.255.255
CIDR: 169.254.0.0/16
NetName: LINKLOCAL-RFC3927-IANA-RESERVED
NetHandle: NET-169-254-0-0-1
Parent: NET-169-0-0-0-0
NetType: IANA Special Use
NameServer: BLACKHOLE-1.IANA.ORG
NameServer: BLACKHOLE-2.IANA.ORG
Comment: This is the "link local" block. It was set
Comment: aside for this special use in the Standards
Comment: Track document, RFC 3927 and was further
Comment: documented in the Best Current Practice
Comment: RFC 5735, which can be found at:
Comment: http://www.rfc-editor.org/rfc/rfc3927.txt
Comment: http://www.rfc-editor.org/rfc/rfc5735.txt
Comment: It is allocated for communication between hosts
Comment: on a single link. Hosts obtain these addresses
Comment: by auto-configuration, such as when a DHCP
Comment: server cannot be found.
Comment: A router MUST NOT forward a packet with an IPv4
Comment: Link-Local source or destination address,
Comment: irrespective of the router's default route configuration
Comment: or routes obtained from dynamic routing protocols.
Comment: A router which receives a packet with an IPv4
Comment: Link-Local source or destination address MUST NOT
Comment: forward the packet. This prevents forwarding of
Comment: packets back onto the network segment from which
Comment: they originated, or to any other segment.
RegDate: 1998-01-27
Updated: 2010-03-15
OrgAbuseHandle: IANA-IP-ARIN
OrgAbuseName: Internet Corporation for Assigned Names and Number
OrgAbusePhone: +1-310-301-5820
OrgAbuseEmail: abuse@iana.org
OrgTechHandle: IANA-IP-ARIN
OrgTechName: Internet Corporation for Assigned Names and Number
OrgTechPhone: +1-310-301-5820
OrgTechEmail: abuse@iana.org
PostPosted: Sun May 02, 2010 11:18 pm
Wild guess:
Windows Vista.
Fix:
http://www.reviewingit.com/index.php/content/view/61/2/
Have fun.
PostPosted: Mon May 03, 2010 2:27 am
Thanks for the help. I have windows 7 though. I still gave it a try but it did not work :-(
PostPosted: Mon May 03, 2010 2:57 am
the 169.254 block is used for windows autoconfig if it can't find a DHCP server. That's why I thought it was Vista since you said wireless. Other problems that may cause this are low signal, incompatibility between the router and the card (Linksys comes to mind).
So when using a wire you have the same problem? Any firewalling software active like Norton or McAfee?
PostPosted: Mon May 03, 2010 11:18 pm
Yeah the problem is there with or without cable.
Although it's only with cable i have the 169.254... ip address. Without cable it just doesn't seem to identify any network :-/
Sometimes it actually randomly works if i boot it up or after playing around with the "diagnose problem" setting. But it's so rare it's not worth fiddling around with.
As for firewall program i have none
I doubt a weak signal's the cause of the problem. My brother's laptop works flawlessly :P
It's just my sister's laptop that doesn't seem to want to work.
PostPosted: Mon May 24, 2010 4:33 pm
I had an issue with my laptop not being able to connect to my wireless lan. I had AT&T's tech guys at the house at least 4 times and they weren't able to solve the issue.
My laptop's internal network card 802.11n draft just would not connect. I used 2 Gateway 2 wire routers no good, the same with Linskys, and some other brand I don't remember. The only router that worked is Netgears n router. Never had a problem since.
It seems that my lappy is picky with routers even after updating the network card drivers etc. Something to think about ???????
PostPosted: Mon May 24, 2010 9:31 pm
Draft-N is picky, since it's not a true standard yet. You should be able to force the card to use B/G only, and skip the N setting, but it should do that automatically..........
Faster than the speed of snot
PostPosted: Tue May 25, 2010 12:07 am
"should do" is the key here. drivers are still very fresh and buggy too...
PostPosted: Tue May 25, 2010 10:21 am
it became a standard september 2009
PostPosted: Tue May 25, 2010 1:54 pm
OP never said how old the laptop and router are, though. :wink: Plus, even with a standard set, you've got how many thousands of draft-N routers and cards out there that don't match it?
