Firewall ports on a FiOS router?
Postby lannaheim » Fri Nov 27, 2009 6:29 pm
Got a nasty virus/spyware which has disabled ability to get online. Is it possible this thing messed up the HTTP ports, and how can I change that? I'm presently running cleaners on the hard drive which I extracted. But if it's in the registry, that won't help. Any ideas?
Outside of a dog, a book is man's best friend. Inside a dog, it's too dark to read.
--- Groucho Marx
A member of Folding Team number 33258 for a cure for PARKINSONS DISEASE
lannaheim
Postby evasive » Sat Nov 28, 2009 12:58 am
Check your hosts file and use malwarebytes.org anti-malware, it will at least detect stuff that has infiltrated your TCP/IP driver stack.
Any idea of a name or family tpe of your malware yet?
Postby lannaheim » Sat Nov 28, 2009 12:31 pm
I am doing those other things. How does a spyware close down PORTS And how can I remove this crisis....? I am so tired of reformatting as the ONLY WAY...
--- Groucho Marx
lannaheim
Postby evasive » Sat Nov 28, 2009 3:02 pm
By loading its own driver that hooks into your TCP/IP driver stack. It does quite early in the boot process. You may have been hit by a rootkit.
How to prevent reformat? By making a regular complete image of your system disk.
Postby lannaheim » Sat Nov 28, 2009 7:58 pm
Are there programs which can eradicate rootkit junk?
--- Groucho Marx
lannaheim
Postby bdub » Sun Nov 29, 2009 8:08 am
after you re-format, you should make an image of what you do... then next time they come to you with a futzed up system, just re-image.
my main rig...
asrock 970 extreme3
AMD FX-6300 Vishera CPU
zalman cpns5x performa hs/fan
powercolor ax7750 1GBK3-H vga
antec neo he 650r
Samsung 840 EVo SSD 120 GB
lg wh14ns40 bd burner
bdub
Postby evasive » Sun Nov 29, 2009 8:33 am
lannaheim wrote:Are there programs which can eradicate rootkit junk?
http://technet.microsoft.com/en-us/sysi ... 97445.aspx
more info:
http://en.wikipedia.org/wiki/Rootkit
if you have a baddie rootkit it is time for a complete reinstall...
Return to Networking
