xbox keeps losing connection to d-link router..
Postby pahoogawoo » Wed Jul 15, 2009 11:02 pm
Recently i did a reformat on my PC.. and i figure that wouldn't effect my router or my Xbox360.. but since i have done this i cant get my wireless connection to my Xbox360 to last more then 2 minutes...
I have a d-link DIR 655... i have set it to wireless b only as the 360 supports only this. i have turned off the wifi protect, i have set up the mtu to 1500, i have it set to a wpa key for security settings but not wpa2....
any thoughts????
pahoogawoo
Postby kornwood » Mon Jul 20, 2009 12:27 am
check out dd-wrt for your router
kornwood
Postby pbailey » Mon Jul 20, 2009 6:16 am
Set the security to standard WEP and not WPA.
Paul
pbailey
Postby beaconengr » Mon Jul 20, 2009 10:42 am
What wireless adapter are you using? The 360 uses 802.11g, not b.
beaconengr
Postby pbailey » Mon Jul 20, 2009 10:45 am
Yes you want to set that up for B and G on the router.
Paul
pbailey
Return to Networking
