wireless router to router
Postby zooofer » Mon Feb 09, 2009 7:20 pm
Greetings all,
I have an odd networking question, at least it is to me. I need to create a network for 3 servers (My servers are part of the Hvac controls and will not be a part of the building network, it will only share the internet connection) in 2 separate buildings that are about 200 ft apart. I might be able to pull a CAT 5, but after pulling to the top of both buildings I'm going to be close to 300' mark. Or I might be able to consult with local i.t. and see if they can lend me a port. But here is my question: Is there a way to have 2 wireless routers (or similar equip.) to communicate with one another? I know that 2 laptops with wireless cards can communicate with one another.
Thanks
zooofer
Postby pbailey » Sun Feb 15, 2009 3:53 pm
Or you could just go with a profesional wireless router that will go the distance for you:
http://www.directron.com/fvg318na.html
with 2 wireless cards:
http://www.newegg.com/Product/Product.a ... 6833150017
Hope this helps!
Paul
pbailey
Postby zooofer » Sun Feb 15, 2009 4:09 pm
Thanks pbailey, thats it, I can mount the super router in one building, plug in my mini server and I will have a pc (human interface) with wireless card in the other with my mini server conected via generic switch. Perfect, thanks
zooofer
Return to Networking
