Small problem after router reboot
Postby evasive » Fri Sep 26, 2008 11:03 pm
tripad wrote:i would say its not a router prob.....
Routers usually save all their settings and even a simple reboot wont affect it !
I would say its a DNS problem...... Try shifting to OPENDns and check if your sites work!
I'm not saying the router itself is the problem but old DNS server entries may be the problem.
Postby Pette Broad » Sun Oct 26, 2008 1:28 pm
I tried a different router, the one that AOL supplied and that cured the problem I was having getting to sites with IE. However this router, a speedtouch, was dropping the wireless connections every few minutes plus it didn't have any of the extended options that I use. It's obviously one of the settings in my Texas Instruments router that's wrong, I'll just have to go through each setting till I find the one that's causing the problem. :(
Pete
Pette Broad
Previous
Return to Networking
