Network Configuration problem, Reintalling 2Wire Home Portal
Postby sfzab » Sun Aug 24, 2008 12:29 am
I had initially my Internet connection configured as follows:
Modem > 2Wire Home Portal 100 W > Router > Computer
in Windows Vista Home Premium. On a certain occasion I
had problems accessing the Internet, and I had to unplug
the cables and I realigned to them as follows:
Modem > Router > Computer
Due to this the 0/S reset my Network configuration that
way, and I do not know how I could change it to work
as before.
I have worked several times with the Windows Vista menu
Control Panel > Network and Internet > Network and
Sharing Center
but I have not been able to "undo" or cancel the second
Network configuration.
Your kind feedback will be highly regarded.
sfzab
Postby evasive » Sun Aug 24, 2008 2:58 am
So you reconnected the portal in between the router and the modem? Then you need to re-configure the router and probably the portal. Not your computer.
Can not access the router
Postby sfzab » Mon Aug 25, 2008 4:03 am
evasive wrote:So you reconnected the portal in between the router and the modem? Then you need to re-configure the router and probably the portal. Not your computer.
I can not access the router using the browser with the present Network configuration.
Do I have to unplug any cables in a certain order?
sfzab
Postby evasive » Mon Aug 25, 2008 4:32 am
Get someone in there with some experience on configuring a home network.
Return to Networking
