Convert Wireless Internet signal to cable ethernet signal
Postby kevinloh » Sat Aug 02, 2008 7:49 pm
A member in my forum asked this relevant question.
He wants to know how to convert his wireless signal from a router gathered from his wireless adapter and output it to the LAN port of the same PC and go through LAN switches to be shared with other computers within a LAN network.
Wireless Router --> Wireless Adapter --> Output to LAN -->Cable connected to Switch -->Manual IP assigned-> Shared amongst other PCs
GIGABYTE GA-X79-UD3
Intel 3930K 3.20Ghz O/C to 4.0GHz
PHANTEKS PH-TC14PE CPU Cooler
16GB CORSAIR DDR3-2133 LP
SAMSUNG 830 256GB SSD SATA3
12TB HDD Drives
EVGA Nvidia 2GB GTX680 Superclocked Signature 2
CORSAIR AX1200W PSU
Sharkoon T28 Green Edition Case
DELL 22 Widescreen LCD Monitor E228WFP
kevinloh
Postby kylepaddock » Sat Aug 02, 2008 8:00 pm
Gateway MT6707 Notebook
Intel Pentium Dual Core T2060 1.6 GHz
Memory 2048 MB 533MHz DDR2 SDRAM
Intel Graphics Media Accelerator 950
224 MB shared video memory
High definition audio 2 channel
160 GB HD
8X Multi-format dual layer optical drive
802.11g wireless LAN
4 USB 2.0 ports
One VGA port
One S-Video
One IEEE 1394
One PCMCIA Slot
If you have done a transaction with me, please fill out my heatware. http://www.heatware.com/eval.php?id=64039
kylepaddock
Postby kevinloh » Sun Aug 03, 2008 1:20 am
Yup that is the hardware my friend is looking for, but I found a way too using Internet Connection Sharing (ICS), however the PC must be on 24/7 to share the internet 24/7. Here is what I suggested :
Install wireless adapter and Ethernet Adaptor on a 24/7 gateway PC running windows XP.
Under Network Connections, since we want to output the signal to LAN port, we right click Wireless Adapter and click Properties, click Advanced Tab and place a checkbox under Allow other network users to connect through this Internet Connection.
The LAN port will then be automatically be assigned a local IP address such as 192.168.1.1 and then can output the signal to the LAN port.
However since we are sharing it to more than one computer, we need to purchase a router/switch and plug in the Ethernet cable to the switch. Perhaps change a setting or two in the Switch settings and you should be able to share the internet across LAN.
GIGABYTE GA-X79-UD3
12TB HDD Drives
CORSAIR AX1200W PSU
kevinloh
Postby evasive » Sun Aug 03, 2008 2:36 am
you don't need a router there, the address translation is already done by ICS. You don't need to manually set IP-adresses on the shared LAN either since ICS also does DHCP if I'm not mistaken...
Postby ajrox » Sun Aug 17, 2008 8:12 am
you need to take into consideration the amount of PCs you plan on running through ICS and the ip addressing / subnet mask as ICS uses its own and you cannot modify it.
AJ
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
ajrox
Return to Networking
