power cycling is such a pain
Postby pgiustino » Sat May 31, 2008 12:49 pm
What is it that makes my internet shut off periodically? Every time it does, I have to turn off/on my wireless router to get it working again. Do I need to tweak something in my router settings to prevent this from happening all the time?
Edit:
[url]http://forums.cnet.com/5208-6142_102-0.html?forumID=62&threadID=214922&start=15[url][/url]
According to this forum, it could either be one of the following:
1. Shotty modem
2. Power spikes and drops
3. DHCP settings
Since the third issue involves the least amount of time and money to deal with, I guess I'll start there. I'll disable DHCP on my router (I have no idea how to mess with modem settings) the next time I need to power cycle and update my progress.
MSI K8t Neo Fis2r
pgiustino
Postby Mr T » Sat May 31, 2008 10:56 pm
Best bet is to borrow another router and see if that is the issue...
Postby filecore » Mon Jun 02, 2008 8:47 am
Quite often upgrading (or downgrading; changing) the firmware can solve problems on a dodgy router. Or on a dodgy PVR, as I recently discovered.
filecore
Postby pgiustino » Tue Jun 03, 2008 1:22 pm
Update: Changing the DHCP settings on my router didn't do anything. I might try changing the firmware, filecore. Since the house is at least 30 years old I'm going to buy a line conditioner and see if that helps.
MSI K8t Neo Fis2r
pgiustino
Postby pgiustino » Tue Jan 06, 2009 11:07 am
Heeyyyyy! I decided to set up my wireless again (I previously got fed up with it and simply wired the connection), so I'm back to sleuthing for a solution to this problem.
I heard a friend say that D-links and Netgear wireless routers (mine's the D-Link DI-634m) are notorious for needing constant power-cycling, and that there are some 3rd party drivers somewhere that may help.
MSI K8t Neo Fis2r
pgiustino
Postby filecore » Tue Jan 06, 2009 11:09 am
Yep, I've seen D-Links need it quite often. Not sure about Netgear, but my Linksys boxes are usually just humming away quite happily, 24/7 (WRT54GL and BEFSX41).
filecore
Postby Karlsweldt » Tue Jan 06, 2009 5:16 pm
A likely cause would be the power mains having surges, spikes or other problems.. like low voltage.
The lines in American homes should maintain a minimal 115 volts (or 210 volts, elsewhere) or equipment can suffer loss of stability.
Late night, with minimal loading on mains, surges are more evident.
Some equipment is more sensitive than others. A line tamer or UPS should smooth out any moderate line conditions, and provide a stable power source.
For power supplies with true transformer cores, they can sustain almost a full second with no 'refresh' of input source. But the switching type power supplies rarely have more than 1/2 second reserve.. and thus show more problems.
Postby pgiustino » Tue Jan 06, 2009 10:08 pm
Wow, it seems a firmware update has been working so far. My friend said he updated it (a while back), but I just found out the version 2.0 was actually the version the router ships with. So version 2.1 might have been all I needed.
Hopefully the thread will help out others with similar situations. Thx for the help guys!
MSI K8t Neo Fis2r
pgiustino
Postby Karlsweldt » Wed Jan 07, 2009 1:40 pm
Good to hear all is well now. Hope it stays that way.
Those updates are issued due to problems found in the field.. after many months, sometimes!
Return to Networking
