Looking for a gigabit switch
Postby ThEvil0nE » Sat May 24, 2008 5:48 pm
I need to connect 12 PCs to the internet. I have very limited knowledge switches.
Looking for:
16 port minimum
mostly used for multi-player online and lan gaming
Mobos I'm using has 10/100/1000Mbps onboard LAN. I also have a D-Link DGL-4100 gigabit router which I would be planing to use with the switch.
I was looking at http://www.newegg.com/Product/Product.a ... 6833122139 but without vlan support. Do i need vlan support? What's best recommended? What other networking hardware/s do I need?
Thanx
Image Image
ThEvil0nE
Postby ajrox » Mon May 26, 2008 8:24 pm
that is perfect for your needs. as switches go, unless you have experience with them, go unmanaged. unmanaged = fire and forget. just plug in the PCs and go.
good luck
AJ
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
ajrox
Postby ThEvil0nE » Fri Jun 06, 2008 10:08 pm
bought the swith I mentioned above.... thanx 8)
Image Image
ThEvil0nE
Return to Networking
