It is currently Sun Nov 18, 2018 10:44 am
Post new topic Reply to topic  [ 14 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 01, 2008 8:12 pm
What model is your linksys router?
This does not look like your linksys ip from your router:
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : up.chartermi.net
Description . . . . . . . . . . . : Wireless-B Notebook Adapter
Physical Address. . . . . . . . . : 00-12-17-47-82-7D
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
IP Address. . . . . . . . . . . . : 24.247.77.31
Subnet Mask . . . . . . . . . . . : 255.255.240.0
Default Gateway . . . . . . . . . : 24.247.64.1
Looks like your charter modem is wireless also.
Have you tried resetting your router with the reset button hole on the back?
You need to hold it down for about a minute or 2!
Paul
PostPosted: Sun Mar 02, 2008 3:52 am
NCan you give us the IPCONFIG on your desktop?
Paul
PostPosted: Thu Mar 06, 2008 6:47 pm
lets try this:
do an IPCONFIG /ALL on both computers. meaning the one that connects and the one that doesn't. this will give us the working subnet which we can get the right info from. we then can get your wireless working.
good luck
AJ
EVGA 790i tri SLI
intel core2 quad 9550
6gb G.SKILL DDR3 16000
3X EVGA 8800gts video cards
water cooled fo sho
the rest when i get paid
PostPosted: Thu Mar 06, 2008 7:20 pm
ajrox wrote:
lets try this:
good luck
AJ
His wireless is working it is the wired system not working!
Paul
