IP ADDRESS INTERNET CONNECTION ISSUE
Postby joeyscales » Mon Feb 18, 2008 1:11 pm
I have a 2 computers a laptop and desktop.
The laptob is connect via a wireless connection through a router and the desktop throught the same router but connected via eithernet cable. I have a cable connection.
The desktop doesn't connect but the wireless connection to the internet does.
The internet provider had me check ipconfig and they said the ip address is wrong.
we also tried ipconfig/renew and I get an error.
How can I change the IP to the right IP address?
joeyscales
Postby greytrains » Mon Feb 18, 2008 1:54 pm
Moved to Networking
Gerald Ford (1913 - 2006)
greytrains
Postby pbailey » Mon Feb 18, 2008 6:01 pm
Need more info:
Who is your provider?
What is your router make and model?
Paul
pbailey
Postby Mr T » Tue Feb 19, 2008 2:00 am
Do you have a static IP address? Are you sure your service provider said IP address and NOT MAC address...
Postby joeyscales » Sat Feb 23, 2008 5:46 pm
Charter communications broadband cable
Linksys wireless router
Static IP address
Every thing was working fine. Both the Laptop and Desktop were connected via wireless connection with the Linksys.
Then I had a motherboard go bad and I had to replace it. Now the desktop(with replaced motherboard) can't connect.
The icon in the system tray says -
Status Connected-
--signal strength good=
==speed 11Mbps
Limited or no conductivity
joeyscales
Postby joeyscales » Sat Feb 23, 2008 5:48 pm
It might have nothing to do with the IP address that is just the direction the so called Tech Support people went down at the cable company.
joeyscales
Postby evasive » Sun Feb 24, 2008 2:26 am
post me the ipconfig /all readout of the laptop. We need to find out if the router is still dishing out IP-addresses or not. If not, you need to set the IP-address of the desktop by hand.
Postby joeyscales » Sun Feb 24, 2008 1:34 pm
ipconfig
Windows IP Configuration
Ethernet adapter Local Area Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : up.chartermi.net
IP Address. . . . . . . . . . . . : 24.247.77.31
Subnet Mask . . . . . . . . . . . : 255.255.240.0
Default Gateway . . . . . . . . . : 24.247.64.1
joeyscales
Postby joeyscales » Sun Feb 24, 2008 1:36 pm
Microsoft Windows XP [Version 5.1.2600]
>ipconfig/all
Host Name . . . . . . . . . . . . : PC180111915653
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Broadcast
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
DNS Suffix Search List. . . . . . : up.chartermi.net
Description . . . . . . . . . . . : Realtek RTL8139 Family PCI Fast Ethe
rnet NIC
Physical Address. . . . . . . . . : 00-0F-B0-4D-0F-DB
Description . . . . . . . . . . . : Wireless-B Notebook Adapter
Physical Address. . . . . . . . . : 00-12-17-47-82-7D
Dhcp Enabled. . . . . . . . . . . : Yes
Autoconfiguration Enabled . . . . : Yes
DHCP Server . . . . . . . . . . . : 68.114.36.66
DNS Servers . . . . . . . . . . . : 24.213.60.93
68.115.71.53
Lease Obtained. . . . . . . . . . : Sunday, February 24, 2008 3:36:32 PM
Lease Expires . . . . . . . . . . : Monday, February 25, 2008 7:26:11 PM
joeyscales
Postby joeyscales » Sat Mar 01, 2008 7:16 pm
Wow, Nobody has an answer? I still haven't been able to connect via my 2nd computer. Ipconfig on the Desktop does not list "up.charter.net" but the laptop does. Maybe that info helps.
joeyscales
Return to Networking
