Remote Desktop
Remote Desktop
Postby Mark H » Wed Dec 12, 2007 11:07 am
Can XP Home be set up to allow incoming remote connection? The wife will be having knee surgery, and I want her to be able to access her PC from the laptop. Maybe a third party app? If not, I guess I'll upgrade her NEW PC to Pro.
Probably not, but gotta ask.......
Mark H
Postby dve83 » Wed Dec 12, 2007 11:32 am
as far as I know, remote desktop has to do with terminal services, which is not available in windows xp home editions. there are however other application that might help.
VNC Free Edition 4.1 might be worth giving a try.
-dve83- Folding for 33258
Gigabyte GA-MA69VM-S2,AMD Athlon X2 5200+, 6GB DDR2-800, Seagate 250GB 7200 RPM, Western Digital 1TB 7200RPM,
460W Coolermaster PSU, Windows 7
"Perhaps it's not paranoia. Perhaps it's just finesse." - dve83
dve83
Postby Copper » Wed Dec 12, 2007 1:37 pm
you need to set up a VPN (Virtual Private Network)
http://www.windowsdevcenter.com/pub/a/w ... ction.html
Copper
Postby Mark H » Wed Dec 12, 2007 9:27 pm
Well, since her old one has a MOBO issue (hard to boot) I'll just do the upgrade with her Pro CD.
Gives me a chance to troubleshoot her P4S533MX.
Mark H
Postby Reader » Mon Dec 17, 2007 3:02 pm
1. This is on the same home network, right? Just going from a PC to a PC? In that case you do NOT need anything like a VPN connection.
2. Both computers must have 'Remote Desktop Connection' under Programs-->Accessories-->Communication
I have no idea whether XP home has that, but certainly XP Pro does.
You can create a desktop icon and store all of the settings. The computer that is being accessed remotely must login with a password and have accounts...Sys Admin accounts. You login from the other computer with that account.
I've remotely managed a computer server with no keyboard/monitor for years doing it.
Hope that helps!
reader
_ _ _____ _ _
"There we were, lost in the Wilds of Afghanistan without a corkscrew. Forced to live for days on nothing but food and water."
W.C. Fields
Reader
Postby Mark H » Mon Dec 17, 2007 6:53 pm
The only problem is, XP Home can only be the "Client" not the "Host". So, I have decided to just install Quickbooks on the laptop, then backup to a flash drive, then restore to her desktop.
I might try to use her OEM Pro to "Upgrade" (After setting a restore point) and see if it works.
Mark H
logmein.com
Postby Impulse » Sun Dec 30, 2007 3:47 pm
Try using this..
www.logmein.com
I'm not sure if anyone else suggested this, so sorry for the repost. I found this pretty useful as I am able to access my dental office from home. They have a free version for just simple use and others for backups, remote printing, drag and drop, sharing files, etc.
I think if you configure it correctly, you can even use it on your iphone or any other pda. Plus, they have great customer service; just takes a while to get hold of them. :roll:
"What doesn't kill you will only make you stronger."
Impulse
Postby Hardware Junkie » Sat Jan 12, 2008 9:08 am
Copper is correct. XP has a VPN capability.
Copper wrote:you need to set up a VPN (Virtual Private Network)
Here is another guide
http://www.windowsecurity.com/articles/ ... ws-XP.html
To be available on the outside world, you'll have to port forward on your router or something though (assuming she is not staying at home)
remote support tools
Postby techcruncher » Tue Jul 08, 2008 4:00 am
I find Techinline Remote Desktop to be more effective than LogMeIn, as I never used 90% of the features they had. Techinline is about 4 times cheaper and is the easiest tool to use from what I've tried so far.
techcruncher
Return to Networking
